I have RPi 2, Raspian Jessie 1-11-2017.
I can ping PI on my LAN. I can SSH into Pi from a Windows 7 machine. I have a user 'rob' who is in the 'adm' group.
It appears that I cannot attach an image of the errors I am getting.
When I attempt to connect with rob I get an error:
Connecting to sesman ip  127.0.0.1 port 3350
sesman connect ok
sending login info ......
xrdp_process_login_response:  login successful ......
started connecting
connecting to 127.0.0.1:5910
error - problem connecting
It seems strange that it says I am connecting to 127.0.0.0 (me) but in a YouTube training video it shows the same thing, but the YouTube video is successful at connecting.
I thought that maybe the xrdp server was not running, but other posts on this site indicate that xrdp is always running.
Any help is MUCH appreciated.
Glorfindel
  • 620
rp108
I had the same problem; here are the links to the solution I found:
error - problem connecting to Raspberry Pi 3 with xrdp
https://ubuntuforums.org/showthread.php?t=1314336
Short answer: Remove: xrdp (you will add it again), vnc4server, and tightvncserver (if not installed these will just be ignored)
sudo apt-get remove xrdp vnc4server tightvncserver
Install: tightvncserver
sudo apt-get install tightvncserver -y
Install: xrdp (only after tightvnc has been installed)
sudo apt-get install xrdp -y
Glorfindel
  • 620
Jon H.
