I was thinking about getting a cable for Pi Zero, this one: https://www.adafruit.com/products/1995
But it's 2.4 ampere, won't that overcharge the little Pi Zero and damage it?
The specifications say that: DC OUTPUT VOLTAGE RANGE MAX 5.36V (+/- 5%)
And the 5% extra is a bit worrying that is already 5.628 V, whereas the maximum tolerance of the Pi Zero is 6 volts, according to the website. That is very close.
So is it safe to use that power supply with Pi Zero, or should I just use the 1 Ampere official power supply?
Ghanima
  • 15,958
  • 65
PiNewbie
  • 47
Just because it can supply 2.4 Amps doesn't mean it will. The Raspberry Pi Zero will draw what it needs to operate and no more. (unless you create a short circuit somewhere...)
There's a great table/matrix here that lists what version draws what power under various circumstances.
Having a supply that is able to supply more (than 1 Amp) is useful if you are adding power supping accessories like WiFi dongles etc.
techraf
  • 4,353
  • 43
KennetRunner
  • 1,050
