It has been a while since I have last used my raspberry pi 2 model B. When turned on its power strip it started to boot and the code was running down the screen but all of a sudden the screen turned black. I could tell that the screen was still on but just a black set. So naturally I turned to the internet for help. Someone else had a similar problem. Their problem was solved when they wiggled the mouse and pressed some buttons on their keyboard and then pressed Alt and F1. When I attempted this my screen flashed a long column of words that were not code but it had something to do with the fact that there wasn't a warranty. Every time I pressed Alt and F1 this screen would flash but my problem was never fully solved. Please help, I would like to get back to coding. Thank you.
Asked
Active
Viewed 122 times
How long has it been? It could be because your software is outdated.
Once you get to the black screen, try pressing [CTRL+ALT+F1]. This should bring you to the hard terminal. Log in like normal and update and upgrade your Pi using {sudo apt-get update} and {sudo apt-get upgrade}.
This fixed my problems a long time ago when I had this problem.
Dallin75
- 71
- 1
- 1
- 9
