9
Like many other Raspberry Pi Zero users out there, I have decided to make a portable retro gaming handheld. One of the larger concerns for me when it comes to this is battery life. The Zero has very little power consumption, although I would love to know if anyone could give me an idea of how long the Pi would last while plugged in with an Adafruit USB Audio Adapter and a 3.5" BW TFT LCD running at 5v, using a 4400mAh lithium polymer battery. If I sound rather noobish - that's because I am :P so please be forgiving if I asked something that may be very simple to answer :D
Thank you so much!
thatoneguy245
  • 355
Similar questions have been asked and answered, you might search for other questions.
Here are a few:
Battery Power Requirements
How long does the RPi last on a battery?
If you want to evaluate the battery life by yourself, those are the considerations. You must evaluate the mean energy absorbed by Raspberry in your project. You can use a 'USB voltage and current tester' to check current need by your progect. If this value is not constant over the time, you have to do a mean.
The power (or if you prefer, the energy need for 1 second) absorbed by the device, is V*I. V for Raspberry is 5 Volt. Suppose, I = 150 mA so P=5*0,15 = 0.75 W or 750 mW.
Now, if your supply is a battery, I suppose you have a DC/DC converter, to convert the battery voltage to Raspberry's voltage. The converter isn't ideal. A small converter may have a performance of about 90%, so for every watt from Raspberry, you need 1.11W from battery. 10% of energy is wasted as heat on the converter.
In the example 0.75W from Raspberry is 0.75/.9 = 0.83 W from the battery or 0.83 W per second. Your battery with 4,4 Ah (or 4400 mAh) at 3,7 volt (I suppose a lithium battery) store an energy equal to 4,4*3,7*3600 = 58608 joule (we multiply by 3600, the seconds on one hour).
The life of your battery, in seconds, is (energy stored on battery)/( absorbed energy), in our example 58608/.83 = 70612 seconds or 70612/3600=19.6 hours.
I did some calculations and research and got at least 22 hours.
According to https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=127210 with a 32GB SD card, composite video and a keyboard, the highest power consumed was 140mA, and with a 4400mAh battery, that's about 22 hours.
Oliver
  • 85
