I have a perfectly running Raspberry Pi 3 Model B, with a Raspbian Distribution on a 16 GB SD-Card. I connected a Screen with a HDMI-to-DVI Connector to it, a Mouse and Keyboard and I also have SSH access. Further I got a Kuman 3.5 Inch Touch-Display, which I want to use on it. I read myself through the Internet enough that I know I can't use the Screen and the HDMI-Screen simultaneously. So I connected the Screen to the right Pins, the Backlight already works. So I take the Drivers that are sent with it. Searched the one for my Distribution, extracted the Script onto my Raspberry Pi and launched it through./LCD-35 in the terminal. After a few seconds it Reboots and the Color-Test appears. The Screen for the NOOBS-Recovery-Mode appears, which I can still use, then a few seconds later:
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
I can unplug it, like I said, the color-test and the recovery and the same again, regardless of having the HDMI-Cable, the Display, USB-Mouse/Keyboard plugged in or not. Before I made a .img of my card so I can flash it again to have my old state, nonetheless, the LCD won't get to work through that.
Can you help me configuring the LCD? I already tried it 2 times this way, both times the same.
UPDATE: I installed a IMG of Raspbian sent with the Display, which worked, let's say 50 %. It worked as a mini-screen, but not more. The touch wouldn't work. I tried to calibrate it, read and did the instructions for my screen, but nothing helped. It's not the original problem but I'd still rather install it on a working system without the special Raspbian.
Nicolas Fischer
  • 101
9 Answers9
Here are the drivers and the description of how to install the screen given by Kumantech. I got it working, and touch screen functionality also worked. I actually did this with combination with other tutorial. Issues I had was that the Pi froze on next reboot, but I'm not sure if error was mine, or just weird faith. I'll be playing around with this now and I'll post my further results.
galoget
  • 107
HelpNeeder
  • 178
  1. Download the driver from here.
  2. Add to /boot/config.txt file the following lines:
    max_usb_current=1
    hdmi_group=2
    hdmi_mode=87
    hdmi_cvt 800 480 60 6 0 0 0
  3. Uncompress, move inside theLCD-show folder and Install it (everything with just one command):
    tar xzvf /boot/LCD-show-YYMMDD.tar.gz; cd LCD-show/; ./LCD35-show
Touch function will work after restart.
galoget
  • 107
jet
  • 379
I had the same problem and here is how I solved it, this is the error message:
[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2).
What I found was that the root file setting in the cmdline.txt entry that the driver tries to install was incompatible with the setting in the original /boot/cmdline.txt.
e.g. The original cmdline.txt has root=/dev/mmcblk0p7 where the driver tries to overwrite it has root=/dev/mmcblk0p2.
After changing mmcblk0p2 to mmcblk0p7, the system boots up and the LCD screen works.
galoget
  • 107
Anonymous
You likely have noobs installed. The premade package by Pi.org. You need Raspbian Jessie-PIXEL. Unfortunately some root files are set up differently in the Noobs installation. To avoid future inconveniences I suggest using Raspbian jessie pixel over noobs. I did this, and it stopped so many errors from occurring. Noobs also prevents the installation of other software and firmware. I always thought Noobs and Raspbian were the same... Guess not.
Hello i had the same problem, i find meanwhile a image that works http://projektsmartmirror.jimdo.com/lcd-display-am-raspberry/
But as soon you upgrade Raspian to the actual version then agein the same error as you get.
I hope this helps to use the diaplay
I had a world of problems with my Kuman provided touchscreen and OS. I emailed them many times and in the end they sent me a new screen (I didn't even get a white screen on powering on) and their .img on a disc. After that I downloaded the latest waveshare driver following the instructions here and all worked - I still have an issue with text not wrapping on the boot screen but I can live with that. Maybe try a fresh Raspbian img and get the latest driver.
L Pee
  • 129
I've also purchased a kuman 3.5 LCD and ran into similar issues. The screen comes with a micro sd card with Raspian already installed with the drivers installed. That was fantastic until 5 minutes later I did
sudo apt-get update
followed by
sudo apt-get upgrade
after the system reboot I would give me the same kernel panic. I contacted the seller and they told me to reinstall the os from the link provided. I did and got it to work but no touch functions. In terminal enter
sudo apt-mark hold raspberrypi-kernel
and that should stop the error when upgrading. You also have to install the correct driver. It's best to do this using ssh.
Ghanima
  • 15,958
  • 65
I had a similar as one of the answers above - including my first ever Kernel panic !
The error message was:
After looking up in the boot partition of my SD card, I saw indeed the cmdline.txt had been modified from the original line:
root=/dev/mmcblk0p7
The LCD driver overwrote it has
root=/dev/mmcblk0p2
I changed the cmdline.txt in /boot/LCD-show/ that used "mmcblk0p2" instead of "mmcblk0p7" to avoid the problem.
I'm still looking for a solution to use both the HDMI and the LCD at the same time.
Bex
  • 2,929
  • 26
  • 34
YAG
  • 101
i had the same issue with a kuman 3.5 inch LCD touchscreen:
  • boot error
  • LCD whitescreen i have the last version of NOOBS (03/12/2017) and the kuman software.
I had the same problem with the error [ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2).
What I found was that the root file setting in the "cmdline.txt" entry that the driver tries to install was incompatible with the setting in the original "/boot/cmdline.txt". E.g. The original cmdline.txt has "root=/dev/mmcblk0p7" where the driver tries to overwrite it has "root=/dev/mmcblk0p2". After changing "mmcblk0p2" to "mmcblk0p7", the system boots up and the LCD screen works.
This actually works but in the kuman software, cmdline.txt file is in /usr repository, do the modification and the basic installation will work.
Enjoy
