12
My RasPi is configured to 900MHz overclock using raspi-config, but it keeps running at 700MHz even under load. I have found this answer already, and my system is also running with dynamic
for info in /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_*
do
  echo ${info}
  sudo cat ${info}
done
Output:
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
700000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
900000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq
700000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency
355000
Even when serving large files via SMB and running apt-get update, the frequency will stay at 700 MHz. Why?
Arne
  • 2,234
  • 35
Even with dynamic frequency set, the Raspberry Pi has a very high default frequency scaling threshold.
To quote this blog post on overclocking the Pi:
The ondemand governor used in the Raspberry Pi will increase the CPU speed to the maximum configured value whenever it finds it to be busy more than 95% of the time. That sounds fair enough for most cases, but if you’d like that extra speed bump even when the system is performing somewhat lighter tasks, you’ll have to lower the load threshold. This is also easily done by writing an integer value to a file (you can put the following for example in the /etc/rc.local startup file):
echo 60 > /sys/devices/system/cpu/cpufreq/ondemand/up_threshold
Here we’re saying that we’d like to have the Turbo Mode kick in when the CPU is busy at least 60% of the time. That is enough to make the Pi feel a little snappier during general use.
You can also set to CPU governor to performance instead of ondemand using a similar command:
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Performance will keep the CPU clocked at 100% all the time. Detailed information about the available modes can be found here: https://www.kernel.org/doc/Documentation/cpu-freq/governors.txt
I made a small programm to automate the process Jonathan Milford described very good. It does this at every boot to make it persist.
Link to my project
MeisterD
  • 41
