I got a Raspberry Pi B 512MB RAM and hooked up a NRF24l01. Now using the TMRh20 library I wanted to configure the radio as followed:
#!/usr/bin/env python
from __future__ import print_function
import time
import sys
from RF24 import *
import RPi.GPIO as GPIO
irq_gpio_pin = None
try:
radio = RF24(RPI_V2_GPIO_P1_15, BCM2835_SPI_CS0, BCM2835_SPI_SPEED_8MHZ)
pipes = [0xF0F0F0F0E1, 0xF0F0F0F0D2]
print('pyRF24 - testing')
radio.begin()
radio.setChannel(60);
radio.setDataRate(RF24_2MBPS);
radio.setPALevel(RF24_PA_MIN);
radio.setAutoAck(True);
radio.enableDynamicPayloads();
radio.enableAckPayload();
radio.setRetries(5,15)
radio.printDetails()
radio.openReadingPipe(1,pipes[0])
radio.startListening()
print("Started to listen..")
while True:
[... stuff ...]
except KeyboardInterrupt:
print("\nProgram manually interupted.")
except:
print("\nUnexpected error:", sys.exc_info())
finally:
GPIO.cleanup() # this ensures a clean exit
Looking at the output of radio.printDetails() it seems like nothing changed (e.g. PA_Power still max and data rate at 1MBPS).
pyRF24 - testing
================ SPI Configuration ================
CSN Pin = CE0 (PI Hardware Driven)
CE Pin = Custom GPIO22
Clock Speed = 8 Mhz
================ NRF Configuration ================
STATUS = 0xff RX_DR=1 TX_DS=1 MAX_RT=1 RX_P_NO=7 TX_FULL=1
RX_ADDR_P0-1 = 0xffffffffff 0xffffffffff
RX_ADDR_P2-5 = 0xff 0xff 0xff 0xff
TX_ADDR = 0xffffffffff
RX_PW_P0-6 = 0xff 0xff 0xff 0xff 0xff 0xff
EN_AA = 0xff
EN_RXADDR = 0xff
RF_CH = 0xff
RF_SETUP = 0xff
CONFIG = 0xff
DYNPD/FEATURE = 0xff 0xff
Data Rate = 1MBPS
Model = nRF24L01
CRC Length = 16 bits
PA Power = PA_MAX
I tried similar stuff with C++ and had the same effect. Also I googled about it, but couldn't find related problems. Therefor I think, that I got a stupid mistake that I'm currently unable to see.
So my question is: What am I doing wrong here? How to configure the radio object?
