You've almost certainly caused a corruption to the SD card.
Assuming you have a Linux machine you can boot into to do some fixing of the card, you can try this guide to recovery (which I blogged about here: http://www.recantha.co.uk/blog/?p=1208)
First of all, find a computer that you can boot into Linux with that has an SD card slot. Boot into Linux, put the card in.
First, figure out what partition we’re dealing with.
sudo fdisk -l
The above will list all the partitions on all the drives in your computer. To recover a lost partition, your going to need Testdisk. Testdisk is included in Parted Magic, and there’s a great guide on their site. For this though, we just need the partition number, such as /dev/sda3 or /dev/hdb1.
Now, make sure your superblock is the problem, by starting a filesystem check, replacing xxx with your partition name. Here, you can change ext4 to ext3, or ext2 to suit the filesystem.
sudo fsck.ext4 -v /dev/xxx
If your superblock is corrupt, the output will look like this
fsck /dev/sda5
fsck 1.41.4 (27-Jan-2009)
e2fsck 1.41.4 (27-Jan-2009)
fsck.ext4: Group descriptors look bad... trying backup blocks...
fsck.ext4: Bad magic number in super-block while trying to open /dev/sda5
The superblock could not be read or does not describe a correct ext4
filesystem.
If the device is valid and it really contains an ext4 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>;
Now lets find where your superblock backups are kept.
sudo mke2fs -n /dev/xxx
Down at the bottom of this output, should be a list of the backups
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
You’re almost there. Finally, restore the superblock from the backup, again replacing the x’s with your partition name, and block_number with the first backup superblock.
sudo e2fsck -b block_number /dev/xxx
Now reboot, and your superblock should be fixed. If it’s not, repeat the steps, but restore a different backup superblock
