I have currently started looking into raspberry pi projects. My background is in C# and Java. I do not have much experience with Python which seems to be the preferred programming language to do raspberry pi projects. I wanted to use the Arduino Motor Shield as my motor controller because it is the cheapest controller I can find that can control 4 separate DC/stepper motors as well as 2 servo motors. I've looked around the raspberry pi forums and found this https://github.com/lipoja/AMSpi to accomplish what I wanted. But there seems to a problem stopping the motors when running the test files. Once the motor starts running it will not stop until I manually turn off the raspberry pi. Can someone help me with this? I am using Raspberry Pi 3 Model B BTW.
Asked
Active
Viewed 1.2k times
I did something similar.
See https://www.raspberrypi.org/forums/viewtopic.php?f=45&t=16118
Also see http://abyz.me.uk/rpi/pigpio/ex_motor_shield.html
The (Public Domain) code I used was
#include <stdio.h>
#include <pigpio.h>
This code may be used to drive the Adafruit (or clones) Motor Shield.
The code as written only supports DC motors.
http://shieldlist.org/adafruit/motor
The shield pinouts are
D12 MOTORLATCH
D11 PMW motor 1
D10 Servo 1
D9 Servo 2
D8 MOTORDATA
D7 MOTORENABLE
D6 PWM motor 4
D5 PWM motor 3
D4 MOTORCLK
D3 PWM motor 2
The motor states (forward, backward, brake, release) are encoded using the
MOTOR_ latch pins. This saves four gpios.
typedef unsigned char uint8_t;
#define BIT(bit) (1 << (bit))
/* assign gpios to drive the shield pins */
/* Shield Pi */
#define MOTORLATCH 14
#define MOTORCLK 24
#define MOTORENABLE 25
#define MOTORDATA 15
#define MOTOR_3_PWM 7
#define MOTOR_4_PWM 8
The only other connection needed between the Pi and the shield
is ground to ground. I used Pi P1-6 to shield gnd (next to D13).
/* assignment of motor states to latch */
#define MOTOR1_A 2
#define MOTOR1_B 3
#define MOTOR2_A 1
#define MOTOR2_B 4
#define MOTOR4_A 0
#define MOTOR4_B 6
#define MOTOR3_A 5
#define MOTOR3_B 7
#define FORWARD 1
#define BACKWARD 2
#define BRAKE 3
#define RELEASE 4
static uint8_t latch_state;
void latch_tx(void)
unsigned char i;
gpioWrite(MOTORLATCH, PI_LOW);
gpioWrite(MOTORDATA, PI_LOW);
for (i=0; i<8; i++)
gpioDelay(10); // 10 micros delay
gpioWrite(MOTORCLK, PI_LOW);
if (latch_state & BIT(7-i)) gpioWrite(MOTORDATA, PI_HIGH);
else gpioWrite(MOTORDATA, PI_LOW);
gpioWrite(MOTORCLK, PI_HIGH);
gpioWrite(MOTORLATCH, PI_HIGH);
void init(void)
latch_state = 0;
latch_tx();
gpioWrite(MOTORENABLE, PI_LOW);
void DCMotorInit(uint8_t num)
switch (num)
case 1: latch_state &= ~BIT(MOTOR1_A) & ~BIT(MOTOR1_B); break;
case 2: latch_state &= ~BIT(MOTOR2_A) & ~BIT(MOTOR2_B); break;
case 3: latch_state &= ~BIT(MOTOR3_A) & ~BIT(MOTOR3_B); break;
case 4: latch_state &= ~BIT(MOTOR4_A) & ~BIT(MOTOR4_B); break;
default: return;
latch_tx();
printf("Latch=%08X\n", latch_state);
void DCMotorRun(uint8_t motornum, uint8_t cmd)
uint8_t a, b;
switch (motornum)
case 1: a = MOTOR1_A; b = MOTOR1_B; break;
case 2: a = MOTOR2_A; b = MOTOR2_B; break;
case 3: a = MOTOR3_A; b = MOTOR3_B; break;
case 4: a = MOTOR4_A; b = MOTOR4_B; break;
default: return;
switch (cmd)
case FORWARD: latch_state |= BIT(a); latch_state &= ~BIT(b); break;
case BACKWARD: latch_state &= ~BIT(a); latch_state |= BIT(b); break;
case RELEASE: latch_state &= ~BIT(a); latch_state &= ~BIT(b); break;
default: return;
latch_tx();
int main (int argc, char *argv[])
int i;
if (gpioInitialise()<0) return 1;
gpioSetMode(MOTORLATCH, PI_OUTPUT);
gpioSetMode(MOTORENABLE, PI_OUTPUT);
gpioSetMode(MOTORDATA, PI_OUTPUT);
gpioSetMode(MOTORCLK, PI_OUTPUT);
gpioSetMode(MOTOR_3_PWM, PI_OUTPUT);
gpioSetMode(MOTOR_4_PWM, PI_OUTPUT);
gpioPWM(MOTOR_3_PWM, 0);
gpioPWM(MOTOR_4_PWM, 0);
init();
for (i=60; i<160; i+=20)
gpioPWM(MOTOR_3_PWM, i);
gpioPWM(MOTOR_4_PWM, 220-i);
DCMotorRun(3, FORWARD);
DCMotorRun(4, BACKWARD);
sleep(2);
DCMotorRun(3, RELEASE);
DCMotorRun(4, RELEASE);
sleep(2);
gpioPWM(MOTOR_4_PWM, i);
gpioPWM(MOTOR_3_PWM, 220-i);
DCMotorRun(3, BACKWARD);
DCMotorRun(4, FORWARD);
sleep(2);
sleep(2);
gpioTerminate();
