As mentioned before, indeed Raspbian OS is not real-time so software controlled PWM will never be fully stable.
But luckily there is hardware support on specific GPIOs! As it is well described on https://techetrx.com/raspberry-pi-tutorials/using-gpio-and-pwm-in-raspberry-pi/:
The Raspberry Pi supports software configurable PWM on all its GPIO pins. You can essentially program a GPIO to output a PWM pulse of a varying duty cycle. Apart from software PWM, it also provides hardware PWM on GPIO12, 13, 18 and 19. It has 2 separate channels for hardware PWM. Channel zero i.e. PWM0 consisting of GPIO12 and GPIO18 and PWM1 with GPIO13 and GPIO19.
To answer to the comment of @joan, the sleep value in Thread.sleep(100); is in milliseconds.
You can find a nice PWM example in https://github.com/Pi4J/pi4j/blob/master/pi4j-example/src/main/java/PwmExample.java
public static void main(String[] args) throws InterruptedException {
// create Pi4J console wrapper/helper
// (This is a utility class to abstract some of the boilerplate code)
final Console console = new Console();
// print program title/header
console.title("<-- The Pi4J Project -->", "PWM Example");
// allow for user to exit program using CTRL-C
console.promptForExit();
// create GPIO controller instance
GpioController gpio = GpioFactory.getInstance();
// All Raspberry Pi models support a hardware PWM pin on GPIO_01.
// Raspberry Pi models A+, B+, 2B, 3B also support hardware PWM pins: GPIO_23, GPIO_24, GPIO_26
// by default we will use gpio pin #01; however, if an argument
// has been provided, then lookup the pin by address
Pin pin = CommandArgumentParser.getPin(
RaspiPin.class, // pin provider class to obtain pin instance from
RaspiPin.GPIO_01, // default pin if no pin argument found
args); // argument array to search in
GpioPinPwmOutput pwm = gpio.provisionPwmOutputPin(pin);
// you can optionally use these wiringPi methods to further customize the PWM generator
// see: http://wiringpi.com/reference/raspberry-pi-specifics/
com.pi4j.wiringpi.Gpio.pwmSetMode(com.pi4j.wiringpi.Gpio.PWM_MODE_MS);
com.pi4j.wiringpi.Gpio.pwmSetRange(1000);
com.pi4j.wiringpi.Gpio.pwmSetClock(500);
// set the PWM rate to 500
pwm.setPwm(500);
console.println("PWM rate is: " + pwm.getPwm());
console.println("Press ENTER to set the PWM to a rate of 250");
System.console().readLine();
// set the PWM rate to 250
pwm.setPwm(250);
console.println("Press ENTER to set the PWM to a rate to 0 (stop PWM)");
// set the PWM rate to 0
pwm.setPwm(0);
// stop all GPIO activity/threads by shutting down the GPIO controller
// (this method will forcefully shutdown all GPIO monitoring threads and scheduled tasks)
gpio.shutdown();
