Has anyone tried this CAN board? It uses the Microchip MCP2515, but I don't see any docs or sample apps.
Qunqi MCP2515 Controller Bus Module TJA1050 Receiver SPI Protocol for Arduino SCM 51
also here:
D33 MCP2515 CAN Bus Module TJA1050 Receiver SPI Protocol
I've also been a board called NiRen that appears to be identical to these.
Shade
Steps you can try: Connections:
  • 5V--VCC
  • GND--GND
  • GPIO10--MOSI (SI)
  • GPIO9---MISO (SO)
  • GPIO25--INT
  • GPIO11--SCK
  • GPIO8--CS
  • Enable SPI on Raspberry Pi edit "/boot/config.txt" to enable SPI and reboot
  • Time for the connections
  • Check whether all connections done right by using "ifconfig can"
  • You will require some basic installs to start. sudo apt-get install git autoconf libtool
and compile the CAN utils.
For any other reference, check:
http://lnxpps.de/rpie/
If you have a MCP2551 IC board, try this
http://chadgibbons.com/2016/01/08/can-bus-hacking-with-the-arduino-and-raspberry-pi/
onedev
