I am getting my RasperryPi Rev2 soon, and I plan to use it as a media centre. I have a WesternDigital Elements 1TB USB3 2.5" USB powered external harddrive. I know that a normal USB port outputs 500mA, and the Pi recommends 700mA in.
I was wondering if I bought a 1.2A PSU, will that be enough to power the external through the RPi's USB ports?
I was looking at this power supply.
Micro USB power supply adapter,Euro,1.2A
Thank you for your help.
KCranky
  • 41
The 500mA is for USB2 (max of 5 loads of 100mA), this drive is USB3 (max of 6 loads of 150mA = 900mA).
External drives often have a (Y or chained) cable that connects to 2 USB ports to get the power needed. Check the specifications of that drive very well before buying anything.
A second reason why that adapter is too tight fit is the surge current (inrush current), a lot of power (relative) is needed to get the disk spinning inside, his is only for a short moment, but in this short moment the current is high, the voltage level might collapse to such a low level that the RPi starts to act weird, or just reboots.
The most safe option is to power the RPi with a separate supply and connect the drive through a powered USB Hub. This ensures that the RPi will not have to deal with any effects from power fluctuations from external devices.
ikku
  • 4,544
  • 26
  • 28
The USB ports on rev 2.0 no longer have the silly poly fuses, but the power to the ports still goes via the main polyfuse.
Increasing the powersupply isn't a great idea, because of this polyfuse and also because it exceeds the specs of the USB socket the PI uses for power.
You should either use a powered hub (yuck) or splice the power cable to the drive (also yuck as this defeats the original purpose of the polyfuse)
John La Rooy
  • 12,005
  • 48
  • 77
