I have some questions before I commit myself into RasPi DYI projects.
  1. What is a breadboard? The usage of it?
  2. Can I connect LEDs or switches (and others), with GPIO pins, without breadboaord, and/or jumpers?
  3. Breadboard is a must, for any projects?
Tan Jia Ming
  • 205
Welcome to the world of RasPi DYI projects.
1) A breadbord is a solderless board for connecting electronic parts and wires. Have a look here: http://en.wikipedia.org/wiki/Breadboard
2) Yes, it is fully possible to connect LEDs and other parts to the RPI without a breadboard. You can use only wires and duct-tape or a soldering iron.
3) I would really recommend buying a breadboard as it makes prototyping a whole lot easier.
Happy DYI-ing BjB
BjB
  • 186
A Breadboard makes it easier to experiment. Here is a breadboard used to connect a LED (and current-limiting resistor) to a GPIO port on a Raspberry Pi. You'll need male-to-female jumper leads.
Breadboard and pi
You can get by without one if you have a soldering iron and don't mind a lot of extra work.
See also
You have to arrange the parts so that there is a "circuit", in my picture, the current flows from the GPIO pin through the white jumper-wire into column 14 of the breadboard and along that column to the anode of the LED, through the LED, down it's cathode lead into column 15, down to row f where a resistor connects to column 30 and a black jumper back to the Pi to complete the circuit.
For more about breadboards See
RedGrittyBrick
  • 611
The answer, if you're intending to mess about with LEDs and switches and that kind of thing is YES, it's definitely a must-have. Jumpers will allow you to "transfer" the GPIO pins to the board and then you plug in your LEDs and other components into the breadboard. You can do everything without a breadboard, but you REALLY don't want to. They are cheap and a way of controlling your wiring.
recantha
  • 4,489
  • 26
