33
I am aware that Linux distributions usually have 'package managers' to allow me to download and install software from the command line, and that I should also be able to download and compile source code from the Web. But I am not sure about how best to do either of these things on the Raspberry Pi.
ЯegDwight
  • 101
Andrew Fogg
  • 5,933
  • 28
Debian
APT is the package manager under Debian, for Raspberry Pi or any other system. The command line tool curl is installed in this example.
You need to be connected to the Internet.
If you haven't done so recently it is worth running,
sudo apt-get update
This updates the list of packages that are available to apt-get.
Then use apt-cache to search for the package that you want to install, in this case,
apt-cache search curl
Every package name or description with the word 'curl' in it will be displayed in a list. This is useful in cases where you are not sure as to the exact name of the package that you want to install.
Once you have the name of the package that you want, install it as follows,
sudo apt-get install curl
If you're not sure what you're looking for or just wish to browse through what's available, you can alternatively use the menu-driven tool Aptitude:
sudo aptitude
Andrew Fogg
  • 5,933
  • 28
Arch
Pacman is the package manager used in Arch Linux.
Synchronize Repositories and update System
$ sudo pacman -Syu
Search for a Package
$ pacman -Ss package
Install a Package
$ sudo pacman -S package
Uninstall a Package
$ sudo pacman -R package
Jivings
  • 22,656
  • 94
  • 140
Fedora
Yum is the default package manager used in Fedora.
Update Installed Packages
yum update
Get Package Information
yum info package
Install New Package
yum install package
Remove Installed Package
yum remove package
MINIBIAN
As MINImalistic raspBIAN is, at its heart, still a Debian derivative, the apt tools are the tools of choice for this really cool OS. Thus, almost anything said about Debian also applies to MINIBIAN, except, of course, since it is not only designed to be "mini", but in fact is minimalistic, there will be a lot of "Ign"(ore) messages while running the "apt-get update" command.
