Can I install the Ruby Version Manager (RVM) on my Raspberry Pi?
Yes!
First, you'll need to install curl, git, and build-essential for your operating system. If you don't know how to install software for your system please refer to How do I install new software?.
Next you need to download and run the bash script they provide.
$ curl -L https://get.rvm.io | bash -s stable --ruby
Next you can do one of two things.
- Close and reopen your terminal session, or
Source the rvm script like so.
$ source ~/.rvm/scripts/rvm
Now you can check if RVM is installed by running the following command.
$ type rvm | head -n 1
rvm is a function
If you get a response like the above one RVM has been loaded and you can install a specific Ruby version. It is recommended that you install the latest stable release; which is Ruby 1.9.3 as of July 11, 2012.
$ rvm install 1.9.3
Now the final the step is to tell RVM which version to use. In order to use a specific Ruby version for the duration of the current terminal session run the following.
$ rvm use 1.9.3
If you want to use that specific version every time you open a new terminal session though you are going to have to tell RVM to set it as the default Ruby. Like so.
$ rvm use --default 1.9.3
Congratulations, you have successfully installed RVM on your Raspberry Pi!
Note
build-essentialis Debian's group forgcc,g++,makeetc. Arch includes a similar group calledbase-devel.
