I just installed motion but I can't get it to work. Im acessing my pi via local IP. SSH, VNC and apache works, but motion simply doesn't. I've already changed the ports at /etc/motion/motion.conf to lots of different numbers but none of them work. I've found this command: sudo motion -n When I run this, I get this message: "Problem enabling stream server in port 7043: Address already in use"
I get this for every port I try. Always when I configure a new port and run netstat -lnutp this port appears in the list and its marked as 'LISTEN'. I try to access but nothing happens. Does my camera need to work to motion at least appears when I try 192.168.1.x:7043? Can't I at least see the server running, even if the camera doesn't work? I'm using a microsoft USB camera, which appears to work with the rPi.
Here's the full list of errors:
[0] Motion thread 1 restart
[1] Thread 1 started
[1] cap.driver: "sonixj"
[1] cap.card: "USB camera"
[1] cap.bus_info: "usb-bcm2708_usb-1.3"
[1] cap.capabilities=0x85200001
[1] - VIDEO_CAPTURE
[1] - READWRITE
[1] - STREAMING
[1] Config palette index 8 (YU12) doesn't work.
[1] Supported palettes:
[1] 0: JPEG (JPEG)
[1] Selected palette JPEG
[1] Test palette JPEG (320x240)
[1] Error setting pixel format VIDIOC_S_FMT: Device or resource busy
[1] VIDIOC_TRY_FMT failed for format JPEG: Device or resource busy
[1] Unable to find a compatible palette format.
[1] ioctl (VIDIOCGCAP): Inappropriate ioctl for device
[1] Could not fetch initial image from camera
[1] Motion continues using width and height from config file(s)
[1] Resizing pre_capture buffer to 1 items
[1] bind(): Address already in use
[1] Problem enabling stream server in port 7043: Address already in use
[1] Thread exiting
UPDATE:
Motion.conf file
