I am trying to get my eth0 interface working on the Pi. It is not getting a DHCP lease - DHCP works perfectly fine over wlan0 though. sudo ifup eth0 is returning:
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/eth0/xx:xx:xx:xx:xx:xx
Sending on   LPF/eth0/xx:xx:xx:xx:xx:xx
Sending on   Socket/fallback
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 19
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
I am running Raspbian 20150216.
Chris
No DHCPOFFERS received is quite self-explanatory. The device your pi is connected to (maybe a router?) is not giving or assigning DHCP offers/addresses. Check your router of it is configured to give out IP addresses (i.e. configure it as a DHCP server, not a relay/client).
Another alternative would be to configure your pi to use a static IP address. This setup would not need any DHCP magic whatsoever. Look here if you would like that.
Aloha
  • 7,176
  • 29
  • 52
With a raspberry pi there can often be power problems. If your ethernet does not work, for debugging, also try
If it works without usb or other devices attached, you may want to
  • use a powered usb hub, connect the devices to that and the hub to the pi
  • use a different power adapter.
You can also check for issues or post new ones in the official issue tracker.
Dej
  • 606
I had exactly the same issue and solved that as explained here with adding a lower priority metric (e.g. metric 100) to the 2nd interface. So based on that finding the following configurations is working for me. If that isn“t done it looks like the routing is confused and is trying to do the DHCP via the LAN connection. In my case I ALWAYS got a IP via wlan on both devices when I have a LAN wire. Did I removed the LAN wire DHCP was also not working via WLAN, the metric part solved my issue.
Config:
auto lo
iface lo inet loopback
auto wlan0
allow-hotplug wlan0
iface wlan inet dhcp
auto eth0
iface eth0 inet dhcp
metric 100
BastianW
  • 180
