How can I perform an upgrade from Raspbian Wheezy to Jessie?
How brave do you feel? It's safest to make a fresh install on a new SD card.
The braver way I'd use is:
Backup any files which are important to you.
With your new or existing install.
sudo apt-get update sudo apt-get upgrade sudo apt-get dist-upgradeto make sure wheezy is fully up to date.
Edit /etc/apt/sources.list and change wheezy to jessie. There may also be files in /etc/apt/sources.list.d/ that also need updating, to replace wheezy with jessie.
Then update and upgrade again
I hope this may help others in the next time: Basically, an upgrade works like this:
- adjusting the sources to "jessie"
- update the package lists and upgrade the packages
- You can either simply replace every "wheezy" in /etc/apt/sources.list (and /etc/apt/sources.list.d/*) with "jessie"
Or you use sed to do the work for you:
sudo sed -i /deb/s/wheezy/jessie/g /etc/apt/sources.list sudo sed -i /deb/s/wheezy/jessie/g /etc/apt/sources.list.d/*.list
This may take quite a while, since everything has to be downloaded and all dependencies need to be rebuilt. Also, the upgrade and dist-upgrade parts require some interaction:
sudo apt-get update
- 1,362
- 1
- 10
- 12
sudo apt-get update
sudo apt-get update
There may be an error after upgrade. Make sure you press N, not Y on prompts related to systemd, lightdm, dbus and other booting related things(Doesn't matter on other programs you can press y) on dist-upgrade to jessie.
Just an addition for users that could land here looking for the upgrade procedure, like me!
On the official Raspberry Pi website the update from Wheezy to Jessie is discouraged. Instead they recommend to make a clean Jessie install.
From https://www.raspberrypi.org/blog/raspbian-jessie-is-here/:
Starting with a clean image is the recommended way to move to Jessie. If you really need to update a Wheezy image, we have tried an unsupported upgrade path which is documented on the forums here. This has been shown to work on a vanilla Wheezy image, but we can’t predict what effect it may have on any packages or data that you have installed, so this is very much at your own risk.
And for those who are brave, this is the forum post where all the passages for the update are explained.
https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=121880
- 203
- 3
- 9
On my raspberry Pi2, after each upgrade, the login service failed, preventing to logon locally. Fortunately I was able to logon remotely through SSH.
Based on my investigation, I found an issue with the dbus service which didn't start anymore after the upgrade.
The workaround I used:
- Reinstall the RaspBian
- Remove the dbus service ==>
apt-get remove dbus - Upgrade to Jessie
Hope it helps.
I found this thread in a Google search. I'm adding my "answer" in case there are others, like myself, still wandering in the wilderness with a now very old, and probably insecure, version of Raspbian. Here goes:
I followed the approach given by Bex (over 3 years ago now!), and it worked :) I did have a minor issue with some failed dependencies at one point, but was able to resolve those by following the suggestions offered in the error message from Raspbian.
All of that said, I feel the "best" approach for most people will be to follow the recommendations in Raspberry Pi's forums, and do a clean install. I've not experienced any issues yet, but my RPI is mostly "stock", being used for the odd experiment now and again. There may still be issues lurking somewhere in my system.
Subsequent to Bex's post, this was posted in the RPI forums:
How to upgrade a Wheezy image to Jessie (both defunct and replaced versions of Raspbian)
And so for anyone who stumbles across this thread while searching for a formula to use in upgrading, I respectfully submit this is the "best" answer.
- 23,558
- 5
- 42
- 83
Cause I'm too lazy and just want to copy'n'paste from now on - the same for Jessie to Stretch:
Update before and clean up
sudo apt update sudo apt full-upgrade sudo apt autoremoveAdjust the repository sources:
sudo sed -i /deb/s/jessie/stretch/g /etc/apt/sources.list sudo sed -i /deb/s/jessie/stretch/g /etc/apt/sources.list.d/*.listUpgrade
sudo apt update sudo apt upgrade sudo apt full-upgrade
- 1,362
- 1
- 10
- 12
