I am a relative newbie to this however I have a couple of raspberry pi's (with the standard out of the box configuration) and was writing a PHP that linked to a df shell command. However I found that the identical command worked on one PI and not the other. On further investigation I discovered that both df's are doing what they should, however the two versions are different - according to the respective man pages, one has a (GNU coreutils 8.23 March 2015) and the other has (GNU coreutils 8.12.197-032bb September 2011). I have tried sudo apt-get update and sudo apt-get upgrade but I can't seem to get the older version of df to update to a newer version. Any suggestions as to how I can force the older df to update?
Thank you !!!
Different Raspbian Releases
Raspbian 8 Jessie closely follows Debian 8 Jessie.
As of this writing, the current version of coreutils on Debian 8 Jessie is 8.23-4
Raspbian 7 Wheezy closely follows Debian 7 Wheezy.
As of this writing, the current version of coreutils on Debian 7 Wheezy is 8.13-3.5
The Pi running coreutils 8.12.197-032bb is probably still on Raspbian 7 Wheezy.
You will need to upgrade to Raspbian 8 Jessie if you want to install the newer version of coreutils.
Hydraxan14
  • 1,876
Your Pi are running different releases. Wheezy is no longer available and not supported (apart from possible security updates).
It is not possible to update from Wheezy to Jessie. You have to do a clean install, although you could just duplicate your Jessie SD Card.
