I've got a DS18B20 Temperature Probe connected to my Pi but it can't seem to detect it.
I run:
sudo modprobe w1-gpio
sudo modprobe w1-therm
and then go to cd /sys/bus/w1/devices and do ls and it shows the file as empty.
I know its not a problem with the sensor wiring or anything physical as I have 2 sensors and 2 Pi's and both sensors work fine on one of the Pi's. Also I note that there isn't a w1_bus_master1 listed which there should be even with no sensor connected.
The problem seems to have been since I reinstalled Wheezy on the Pi (due to issues in other stuff I was doing) as before that, it worked fine so I feel like i've simply missed some download/upgrade I need for it to work that i did originally and have now forgotten. I've run plenty of apt-get updates and upgrades but have had no luck.
Anyone have any ideas?
KernelPanic
  • 438
Kersakov
  • 425
Added the line:
dtoverlay=w1-gpio-pullup,gpiopin=x (where x is my gpio pin)
to /boot/config.txt as suggested in the comment.
Kersakov
  • 425
If you have a newer version of Wheezy, DO NOT enable "Device Tree" in the Configuration program! I find that it cause all kinds of havoc with you Pis' hardware.
Doing so, you WON'T have to add the line mentioned above.
piboy
