I have read through the question What power supply should be used for the B+ model? to find the best power supply for the B+. I have read that if you are connecting additional things to the Raspberry Pi, 1.5 A may not be enough.
What reliable power supply can be recommended to buy (preferably 2 A as per the reason above, and 5 V as recommended in multiple sources)? A power supply on Amazon advertises 2 A, but it actually delivers 1.5 A only, as seen by some rather dissatisfied reviewers.
Is there a link or two for where to buy a good power supply for the B+ model?
warship
  • 111
I can thoroughly recommend the power supplies provided by The Pi Hut in the UK. They deliver a steady 2A supply and are of very high quality.
recantha
  • 4,489
  • 26
This one is clearly one of the best I could find. It's 5.25 V to compensate for the resistance of the cable and is quite practical since it has no cable, but a USB connector that allows you to connect virtually any USB cable you may have, with different output connector.
Peter Mortensen
  • 2,004
tchap
  • 251
It depends what you are looking for. Recently I read this research, which was very informative for me. If you need high quality audio, I recommend reading this information:
http://www.lygte-info.dk/info/usbPowerSupplyTest%20UK.html
This is not to suggest which models should be promoted, but rather to give an idea what kind of specifications are relevant for a power supply, given a certain application or requirement.
iep
  • 198
