I'm making a powered daughter board to mount my B+ Pi on. Can I power the Pi entirely through the 5v pins on the GPIO header?
More importantly, can I also supply reasonable currents to USB devices through these pins?
Am I right in thinking this has changed between the B and B+?
Tim
  • 141
Yes, you can power the B and the B+ through the 5V and ground pins on the expansion header.
The difference between the B and B+ in this area is that on the B+ you can no longer backpower the Pi through the USB ports.
EDITED TO ADD
You can actually backpower the A+/B+/Pi2 via the USB ports, albeit in a pretty useless way. Once the Pi has been booted via power from the microUSB or expansion header it is then possible to backpower from the USB sockets.
joan
  • 71,852
  • 76
  • 108
It has always been possible to power a B through the GPIO. An unstated requirement is to ensure the supply is well regulated and not activate the overvoltage/transient protection diode. The recommended practice for HAT is to use an isolation circuit (similar to that on the B+). On the B+ USB can use 600mA/1200MA (depending on settings).
