I currently have an SD card with a non-running installation of Debian Squeeze. SSH on this card is enabled. However the system keeps rebooting. I would now like to delete the boot.rc file on the boot partition of the SD card from a Windows computer, but I fail.
Here is the problem: I have a Windows pc with an internal card reader (the only card reader available at the moment). I enter the card and can access it and rename boot.rc or delete it. But when I remove the card and put it back again, the boot.rc is back again or has its old name back. Deleting other files on that image results in the same - no effect. I tried pulling it out of the reader without unmounting and unmounting via the taskbar in the lower right Windows corner.
Could you please explain to me, how I can delete/rename boot.rc on the SD card with a Debian installation? Do I have to follow a special unmounting procedure? Right-clicking the SD card in Windows Explorer has a menu item "SG eject", but that shows no effect.
Till B
  • 2,363
This kind of "repairs" must be carried out under Linux, just because Windows is not reliable and generally too "invasive" for such things.
As suggested in the other answer, a Linux LiveCD could be the fastest solution. My favorite LiveCD/USB distribution is Knoppix but DSL could be sufficient for you specific case.
A similar solution (if you don't want to burn CDs or write USB pens) is to run a live distro inside a VM, giving to it the exclusive access to your card reader.
For what concerns your specific problem, my guess is that Windows is mounting the SD card filesystem read-only. BTW, Windows can't access ext2/ext3 partitions directly, so if you used an ext2/ext3 driver such as IFS probably you forgot to set its RW permissions.
Avio
  • 1,239
Boot from Linux LiveUSB/LiveCD and try again...
cupakob
  • 1,057
