16
I have come across the RPi Advanced Setup but there are incomplete steps. For example, where can I find mkcard.txt from the Advanced SD card setup section? Do I just reuse the one from the BeagleBone demo site? Then there is an important steps section under Finally booting GNU/Linux that only contains the text "to be completed".
Does anybody know what additional things need to be done to boot into a Debian release for example?
tlhIngan
  • 3,372
  • 33
Joe
  • 713
The content of RPi Advanced Setup states that it is based on BeagleBoardBeginners and mkcard.txt is a script that formats and partitions an SD card. It appears that this script could be used for systems other than BeagleBoard but I am guessing that the Advanced Setup authors want to figure out what customizations, if any, may make sense for the RPi.
@AlexChamberlain pointed out and some research confirms the the VFAT partition is important for booting a Linux system from flash like that used with the RPi.
If you do not require instructions that generate an empty (but partitioned) filesystem on your SD card, you can download a pre-made image and setup an SD card more easily; see How do I install an OS image onto an SD card?.
deaks
  • 326
It is not clear what makecard is supposed to do. I guess it partitions the SD card - use fdisk - and copies the image on - download from the website and use dd.
Alex Chamberlain
  • 15,638
