Title says all. does these cheap power adapters can harm my Pi anyway?
and also, lets say these things stop providing less than what required (less than 5v and less than 0.7A), what will happen to my Pi? will get burn or get damaged irreparably Or it will just quietly shutdown protecting itself?
avi
  • 513
Impossible to say. If it puts out less than 5.5V it is unlikely to harm the Pi or attached peripherals (one of my Pi's has been powered from 5.8V for months without any obvious harm).
If the voltage is too low the Pi may not boot or may reset itself. That won't harm the Pi but may corrupt the SD card you are booting from.
joan
  • 71,852
  • 76
  • 108
If it fits a Blackberry phone, it fits a Raspberry Pi.
Just to be clear, Blackberry phones use MicroUSB plugs and output 5V. If you want to be sure, use a multimeter to check the output of the charger.
Another test would be to connect the power without the SD card in and paying attention to the LEDs: http://elinux.org/R-Pi_Troubleshooting
Beta Decay
  • 400
I have been using noname power adapters for a while for some of my pies, and it seems to work fine.
If you want stability, you should make sure they can output at least 700mA, and some more if you are planning to use any USB peripherals. If the power drops below what the pi needs it will reboot. Now, depending on what you use it for, it might be that the only thing you notice is a drop in your uptime statistics - but reboots can corrupt your SD-card. This won't destroy your pi, or probably even the SD-card, but you will loose any data and you will have to reflash your SD-card.
Bex
  • 2,929
  • 26
  • 34
"90% of all problems are power supply." As the hardware guru used to tell us when I started hardware design out of school. Current capacity matters.
Make sure you have at least one good heavy duty power supply (like Nexus 7 2A job) so you can debug/eliminate the psu from odd problems... my odd problem was failure to boot headless solved when monitor plugged in!!!?...tracked down to the original psu being responsible ... under spec or something.
d586
  • 216
