Running Raspberry Pi-5 with Wayland (and labwc). Would like to use CAPSLOCK key as a control key. The suggested techniques below do not appear to work. They are all pretty old. Is there a way that works with my OS / config? Thanks!
Tried answers found in this question.
Tried updating /etc/default/keyboard and running dpkg-reconfigure. No effect.
Tried 'setxkbmap -option caps:ctrl_modifier'. Got 'WARNING: Running setxkbmap against an XWayland server'. (Also tried 'caps:nocaps' - same warning; did not change CAPSLOCK behaviour.)
Tried 'xmodmap my_fix' where file my_fix is:
remove lock = Caps_Lock
add lock = Control_L
Got
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode: 118 X_SetModifierMapping
... snip...
Tried to use the Keyboard Layout Handler' in Panel Settings - but no idea how to get to that. It says to start by right-clicking on 'panel' - but there is no 'panel', only the task bar at the top of the screen. And in any case, it says to use setxkbmap - which I tried 'manually'.
