I have a FTDI USB-Serial (UART) IC connected to my Raspberry Pi. When I type lsusb I can see all my USB buses:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 050d:705c Belkin Components F5D7050 Wireless G Adapter v4000 [Zydas ZD1211B]
Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
I am using python-serial to communicate with the USB via Serial. For this I need the address:
ser = serial.Serial('/dev/ttyUSB0',  9600, timeout = 0.1)
By trial and error I determined the address is /dev/ttyUSB0. I went to directory /dev/ and took a guess. Where can I find a mapping of (in this case) Device 0005 to the actual address?
Getting the USB tree lusub -t yields:
lsusb -t
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/3p, 480M
        |__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
        |__ Port 2: Dev 5, If 0, Class=vend., Driver=ftdi_sio, 12M
        |__ Port 3: Dev 4, If 0, Class=vend., Driver=zd1211rw, 480M
but does not tell me the address.
PhillyNJ
  • 1,210
  • 28
After plugging in the device, (or after boot if it's already plugged in), you should see in dmesg what the device has been registered as in /dev. The device registration will also trigger a udev call. You can create a custom rule to always assign it to a specific device.
For example, creating a /udev/rules.d/90serial file with this should work, and create /dev/myUSBserial:
SUBSYSTEM=="usb", ATTR{idVendor}=="0403", MODE:="666", SYMLINK+="myUSBserial"
More info.
Fred
  • 4,592
  • 29
You will find it using lshw command:
lshw -businfo -numeric -class usb
Will print everything you need. Non-standard Debian but useful, you may want the hwinfo command which produce detailed informations.
jlandercy
  • 446
