I have a Raspberry Pi 4 B running with the latest updates and want to operate a pushbutton "shutdown / restart". I have set up the pushbutton as described ín various articles but no success. With an older version of raspberry os it worked fine, so the hardware should be ok.
I have looked at the rpi-eeprom config, it shows this:
BOOT_UART=0
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=0```
My config.txt is this
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
#dtparam=spi=on
# enable_uart=1
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
max_usb_current=1
# Start/Stop Taster Konfig
dtoverlay=gpio-shutdown,gpio_pin=21
# Grafikspeicher
gpu_mem=256
# Turbo Mode
# force_turbo=1
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
hdmi_force_hotplug:0=1
hdmi_force_hotplug:1=1
hdmi_drive=2
</code></pre>
<p>In the graphical "settings - interfaces" mask nothing else than "camera" and "SSH" is active.</p>
<p>I'm at a loss what else I could do to get the bugger to do what's expected.
Please consider that I'm:</p>
<ul>
<li>old</li>
<li>a noob</li>
<li>and a little slower in thinking by now
I'd really appreciate any (good :-) ) tip helping me out.</li>
</ul>
<p>EDIT:</p>
<p>I have just tried it again and have added the parameter "active_low=1" to the "dtoverlay" - line and suddenly everything works !!!</p>
<p>I don't remember that this param was necessary before.</p>
<p>So, everything is solved !</p>
