I've been through tags "power-supply" and "power" of this website and surfing on a lot more but I did not found any answers or information about the subject I'm about to talk about.
So, I'm looking forward to design and implement a solution that will :
1 - detects when the power-supply can't supply anymore (like a power shutdown from the building) and gives a bit to one of RPi's GPIOs.
2 - when detecting (1), having a script to "sudo halt" the Pi.
3 - supply enough power and buy enough time for the Pi shutdown properly
Please find below what HW and OS I have : HW : - RPi rev B - Power supply : 5V - 1500mA - Class 10 SD card, SanDisk 16GBytes - Wifi Dongle (no reference, sticker ran away)
OS : Raspbian (updated, a few packages added)
The main purpose of this is to protect the Pi's SD card from getting corrupted.
The second part of the project is to add a timer (at least the time for the Pi to shutdown) that will block the power-supply (with a relay or MOS-FET transistor) for the Pi to boot again when power will be available again.
I already have a few ideas but none of them seem to be time-resistant.
Here are the questions :
Does a 10 seconds power-supply will get the Pi enough time to "sudo halt" ?
Might a relay on the power input be dangerous for the Pi ?
Thanks for your time, knowledge and help.
Raspberry Pi-ly yours,
TDT
TDT
Timing question
The answer is unfortunately - no, there is no amount of time that is sufficient for RaspberryPi to halt. The time is not constant and it depends on what packages are installed (each package may add additional shutdown script) and what is happening on the system. It is possible that it will not shutdown cleanly at all. So there is no warranty.
What you can do is to test what is the typical time your system needs to shut down and use this as a reference value, then add some buffer to this.
Relay question
Using relay should not be more dangerous to the Pi than physically disconnecting it from the power and this is actually the only way you can power it off.
As far as I know, the only problem with relays is that there is some energy in the coil which may produce voltage spike in it's circuit. This may be prevented by the diode but this is not always enough (but those are rare cases). This shouldn't be a problem for RaspberryPi, however, since it won't be connected to the coil circuit (it won't be controlling the relay).
Also, if you are going to control AC voltage for the power adapter connected to the Pi instead of 5V connected directly, there is even less concern here - it's much harder to damage power adapter than RapsberryPi.
Please keep in mind that I'm not an electronics expert so I may be missing something in that regards.
Side note
You may be interested in ATXRaspi project. It tries to solve quite similar (but not identical) problem as you. In first revision, it used relay but they had some problems (but not related with damaging RaspberryPi) and started using MOSFET instead.
Krzysztof Adamski
  • 9,605
  • 38
  • 53
You can also attach some sort of those USB Battery Packages that allow passthrough when charging the package.
When the power cuts (or I don't know how you call it, English is not my native language) your Pi will continue to run until the Battery is empty (mine can charge my iPhone up to 3 to 4 times max.; 5400mAh capacity)
Obviously you won't get any notification or something to the GPIOs but this is an alternative maybe? of Course if you're tech-savy (don't know how to spell it) in the means of wires etc. You can do something with these things that when the power cuts a device BEFORE the battery pack (or the battery pack itself if it's a "smart"-battery or you make it smart) you get a notification and then shut the Pi down by yourself or something. Don't blame me if it isn't possible, just using my imagination over here
I don't dare to guess how long your Pi will survive on that battery before it's empty, but it depends on the battery capacity
Subject
  • 83
This is an old question, and while the answers were relevant at the time, more recent Raspbian distributions include functionality to detect safe poweroff.
While there is no means of detecting loss of power (without additional circuitry) there are indicators to show when it is safe to remove power.
You can set the Pi to assert a GPIO output on poweroff.
dtoverlay=gpio-poweroff
This is intended for use with external power circuitry.
See https://raspberrypi.stackexchange.com/a/89298/8697
