I'm trying to install Wine on a 32-bit Raspbian using Pi-Apps. I have already successfully installed Box86 emulator from the same place. However, Wine installation ends in a segfault:
Installing Wine (x86) with install-32 script
Your system is using a 3G/1G kernel. Continuing...
Running pkg-install...
Waiting until APT locks are released... Done
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
output: Reading package lists...
Building dependency tree...
cabextract is already the newest version (1.9-1).
No new packages to install. Nothing to do!
--2021-02-27 17:34:38--  https://twisteros.com/wine.tgz
Resolving twisteros.com (twisteros.com)... 185.199.108.153, 185.199.109.153, 185.199.110.153, ...
Connecting to twisteros.com (twisteros.com)|185.199.108.153|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 67938781 (65M) [application/octet-stream]
Saving to: ‘/home/pi/wine.tgz’
/home/pi/wine.tgz 100%[=============================================================================>] 64.79M 15.4MB/s in 4.3s
2021-02-27 17:34:44 (15.2 MB/s) - ‘/home/pi/wine.tgz’ saved [67938781/67938781]
--2021-02-27 17:36:32-- https://raw.githubusercontent.com/Winetricks/winetricks/master/src/winetricks Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.110.133, 185.199.109.133, 185.199.111.133, ... Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 879667 (859K) [text/plain] Saving to: ‘/usr/local/bin/winetricks’
/usr/local/bin/winetricks 100%[=============================================================================>] 859.05K 3.53MB/s in 0.2s
2021-02-27 17:36:32 (3.53 MB/s) - ‘/usr/local/bin/winetricks’ saved [879667/879667]
Box86 with Dynarec v0.2.1 db176ad3 built on Feb 15 2021 00:05:11 Box86 with Dynarec v0.2.1 db176ad3 built on Feb 15 2021 00:05:11 Box86 with Dynarec v0.2.1 db176ad3 built on Feb 15 2021 00:05:11 008c:err:clipboard:convert_selection Timed out waiting for SelectionNotify event 008c:err:clipboard:convert_selection Timed out waiting for SelectionNotify event 00b8:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution. 00b8:fixme:dwmapi:DwmIsCompositionEnabled 6D95DD14 00c0:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x6a0df537, context 0xe29060, init_notify 0, handle 0x166fce8): stub 00b8:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION wine: configuration in L"E:\home\pi\.wine" has been updated. First wineboot finished. Now updating wine prefix... /usr/local/bin/wine: line 2: 8256 Segmentation fault setarch linux32 -L /home/pi/wine/bin/wine "$@"
Installed Wine (x86) successfully.
Closing in 30 seconds.
Subsequent calls to wine also result in a segfault:
pi@raspberrypi:~ $ winecfg
/usr/local/bin/wine: line 2: 15171 Segmentation fault      setarch linux32 -L /home/pi/wine/bin/wine "$@"
pi@raspberrypi:~ $ wine explorer
/usr/local/bin/wine: line 2: 15174 Segmentation fault      setarch linux32 -L /home/pi/wine/bin/wine "$@"
Any ideas what might be wrong? Box86 is working as far as I can tell. I tried reinstalling both Wine and Box86, rebooting, and wiping the ~/.wine folder before installation.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
After some troubleshooting the issue was identified: Wine (x86) fails to run if there are other handlers for x86 ELF files than Box86. The solution is to remove other emulators (QEMU, Exagear, etc.) from the system.
As a side note, Wine + Box86 are amazingly fast, for instance, StarCraft and Heroes of Might and Magic 2 run full speed on a Pi 4. Many games will still fail to run at this point, but Box86 being an open-source project (and quite recent) makes me believe the situation will improve with time.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
