I want to know if it is possible to supply power to raspberry pi 3 with AA batteries.
Some electronic boards like Arduinos contains a voltage regulator. The Vin voltage input can be greater than 5V.
But i don't know if raspberries devices contains a regulator. Do they need exactly 5V ?
Thanks
Bob5421
  • 107
Yes, can be done with a voltage converter.
I use 6x AA NiMH Eneloop Pro batteries which give about 7.2 volts along with a voltage/buck converter to step the voltage down to 5 volts.
CoderMike
  • 7,102
The maximum input voltage is 5.25v and a standard aa battery is only rated to supply 50ma of current so running a pi from aa batteries is not really feasible
Bra1n
  • 1,261
There are many things wrong with this approach.
AA batteries are not capable of supplying sufficient current; NiMh cells would be marginal.
The Pi has no regulator and operates over a narrow voltage range.
