I am trying to get a virtual environment for Django development but I cannot get it working.
So far I have:
sudo pip3 install virtualenvwrapper
I have then added the following to /home/pi/.bashrc
export WORKON_HOME=$HOME/.virtualenvs
export VIRTUALENVWRAPPER_PYTHON=/usr/bin/python3
export VIRTUALENVWRAPPER_VIRTUALENV_ARGS=' -p /usr/bin/python3 '
export PROJECT_HOME=$HOME/Devel
source /usr/local/bin/virtualenvwrapper.sh
I then reload the startup file:
source ~/.bashrc
And finally I run:
mkvirtualenv my_django_environment
Which outputs the following:
created virtual environment CPython3.7.3.final.0-32 in 460ms creator CPython3Posix(dest=/home/pi/.virtualenvs/my_django_environment, clear=False, global=False) seeder FromAppData(download=False, pip=bundle, setuptools=bundle, wheel=bundle, via=copy, app_data_dir=/home/pi/.local/share/virtualenv) added seed packages: pip==20.2.2, setuptools==49.6.0, wheel==0.35.1 activators BashActivator,CShellActivator,FishActivator,PowerShellActivator,PythonActivator,XonshActivator virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/my_django_environment/usr/local/bin/predeactivate ERROR: Environment '/home/pi/.virtualenvs/my_django_environment' does not contain an activate script.
I'm guessing that this is my problem:
I've not found any recourse online, only these ERROR: Environment '/home/pi/.virtualenvs/cv' does not contain an activate script & https://stackoverflow.com/questions/60252119/error-environment-users-myuser-virtualenvs-iron-does-not-contain-activation-s/60292344#60292344
Neither of which solve my error. Any ideas?
It is unclear what you are trying to do BUT one thing is clear:-
.bashrc is NOT intended to run scripts.
It is run each time a non-login interactive shell is started and is used to configure the shell.
~/.bashrc: executed by bash(1) for non-login shells.
It seems I was missing a line...
And I fixed it by placing the following in /home/pi/.bashrc:
export VIRTUALENVWRAPPER_ENV_BIN_DIR=bin
And then reloading again:
source ~/.bashrc
This then gave me access to commands such as workon etc..
HOWEVER - I have been advised that putting such stuff in .bashrc to get stuff to run at start up is not what .bashrc is for. But I'm new to Linux so I don't know. But what I did, achieved what I was trying to do, rightly or wrongly..
