10
I am trying to install opencv 4 on my raspberry pi 4 using these instructions from this website but I have come across an error when I run the command mkvirtualenv cv -p python3.
The error is found below. Please do help me guys as I have searched on google and tried this soltuion mentioned but it still gives me the error message.
pi@raspberrypi:~ $ mkvirtualenv cv -p python3
created virtual environment CPython3.7.3.final.0-32 in 451ms
  creator CPython3Posix(dest=/home/pi/.virtualenvs/cv, clear=False, global=False)
  seeder FromAppData(download=False, pip=latest, setuptools=latest, wheel=latest, via=copy, app_data_dir=/home/pi/.local/share/virtualenv/seed-v1)
  activators BashActivator,CShellActivator,FishActivator,PowerShellActivator,PythonActivator,XonshActivator
virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/cv/usr/local/bin/predeactivate
ERROR: Environment '/home/pi/.virtualenvs/cv' does not contain an activate script.
Mohi Rostami
  • 4,434
  • 39
user3880651
  • 189
I'm running on a raspbian buster with Python 3.7.3. I ran into the same issue, "ERROR...no activation script". I tried @Lombax answer but it didn't work.
However, I noticed that the version of virtualenvwrapper I had installed was 5.0.0. I checked on PyPi and it's still at version 4.8.4. So I uninstalled virtualenv and virtualenvwrapper: sudo pip3 uninstall virtualenv virtualenvwrapper.
Then I reinstalled both and specified the version: sudo pip3 install virtualenv virtualenvwrapper=='4.8.4' I sourced my .bashrc, in which I had appended the settings:
VIRTUALENVWRAPPER_PYTHON=/usr/bin/python3
VIRTUALENVWRAPPER_VIRTUALENV=/usr/local/bin/virtualenv
export PATH=/usr/local/bin:$PATH
export WORKON_HOME=~/.virtualenvs
source /usr/local/bin/virtualenvwrapper.sh
And now mkvirtualenv test works. Not sure what's the bug with version 5.x of virtualenvwrapper, in the meantime, this got around the problem for me, hope this helps.
vinay kumar
  • 131
I am also facing the same error. You must add these lines on ~/.profile
export WORKON_HOME=$HOME/.virtualenvs export VIRTUALENVWRAPPER_PYTHON=/usr/bin/python3 export VIRTUALENVWRAPPER_VIRTUALENV=/usr/local/bin/virtualenv source /usr/local/bin/virtualenvwrapper.sh export VIRTUALENVWRAPPER_ENV_BIN_DIR=bin
Abdul Basit
  • 211
I am using pyenv instead and it is working well. There is an excellent article by ReadPython on how to use it.
I updated my environment with the tools suggested in the article.
sudo apt-get install -y make build-essential libssl-dev zlib1g-dev libbz2-dev libreadline-dev libsqlite3-dev wget curl llvm libncurses5-dev libncursesw5-dev xz-utils tk-dev libffi-dev liblzma-dev python-openssl
Then I installed pyenv and updated my .bashrc.
I decided to install Python 3.8.2 for use with CV. This takes a little while to compile.
Then I created a virtual environment:
pyenv virtualenv 3.8.2 cv
Next, I created a directory called cv to do my work in.
Finally, I enabled the virtual environment by cd'ing into cv and then used the following command:
Now when I cd into the cv directory I am in a virtual environment using Python 3.8.2 and when I exit that directory I am no longer in a virtual environment and back to using Python 3.7.2.
Activation is automatic.
