I have a 3 axis rf meter. This one. I wanted to see if I could make it with a rasp pi instead.
I found this article using the AD8361 but it doesn't go up to 3.5ghz and its not 3 axis. Ideally I would like it to go higher.
The main features I need to build are;
-RF range: 38mV to 20V/M -Frequency range: 50MHz to 3.5GHz. -Sensors:Triple Axis (X,Y,Z)
The first two I believe I can get with AD8362, I have no idea how to get the 3 axis?
I believe I can just record the data and get the required features;
-Manual data memory (Max & AVG) records -Calibration factor, Alarm and Clock settings
Can someone point me in the right direction? Is this even reasonable?
Denis
How to DIY a Rpi based Triple Axis RF Detector using AD8362?
ad8362
(1) Using 3 AD8362s
You can use 3 AD8362s (in X, Y, Z direction) and 3 ADCs, eg, MCP3008 (or ADS1015) x 3 for Rpi. Analog Devices is hacker friendly to give the PCB layout and BOM.
(2) Using 1 AD8362
You can use 2 little servos, TowerPro SG90 eg, to sequentially position to X, Y, Z axis and take reading.
(1) AD8362 50 Hz to 3.8 GHz 65 dB TruPwr Detector Data Sheet - Analog Devices
(2) AD8361 LF to 2.5 GHz TruPwr Detector Data Sheet - Analog Devices
(3) How Can I read data from AD8361 RF Detector - Asked 2020mar15, Viewed 38 times
(4) Amazon Latnex HF-B3G Triple Axis HF RF Power Meter Analyzer and Detector Measuring EMF Radiation-Cell Phones-Smart Meters-Cell Towers-WiFi-Microwave-Blouetooth-Calibrated-Used for EMF Home Inspections
(5) AD8362 Documentation (Datasheet, Application Notes, Evaluation Board)
(6) AD8362 Eval Board Gerber File
(7) ADP7102 20V, 300mA, Low Noise, CMOS LDO Data Sheet - Analog Devices
(8) AliEXpress Panoramic Servo Mount Platform Anti-Vibration for SG90 - US$0.5
(9) Mono-axial and tri-axial (isotropic) probe / EMF measurement - Wikipedia
(10) AliExpress AD8362 Catalog
(11) AliExpress AD8362 RF module RMS power detector - US$22
(12) AliExpress 10 pieces AD8362 - US$7.8/10 units
(13) Best EMF Meters Reviewed - GeoEmf 2020
(14) EMF Protection Devices – Do They Work? - GeoEmf 2020
Appendices
Appendix A - AD8362 Summary
AD8362 Summary
Appendix B - AD8362 Evaluation Board Design Notes
AD8362 PCB
Appendix C - SG90 Servo Mount
sg90 servo mount
Appendix D - AD8362 RF module RMS power detector product datasheet summary
AD8363 Summary 1
AD8362 Summary 2
End of Answer
