I’m connecting a NO reed sensor to 3.3v and GPIO17. In my code I defined GPIO17 as input and set the internal resistor to pulldown.
When the door is closed, GPIO 17 reads 1 and 0 when the door is open.
The code works flawless and does what I want it to do, but since the door is closed 99% of the time I’m concerned about safety and power draw.
Is this circuit safe, or is there a risk of damaging the pi? Since there is not any resistor in the circuit, how much power does it draw?
EDIT #1
I've changed my setup to this as suggested by Milliways Reed Circuit
Unkn0wn
This would be "safe", but not best practice and subject to interference.
The internal pullups are very high impedance; use a lower value resistor. Unless the leads are very short and/or shielded you are likely to pick up inteference.
It is hazardous running leads connected to 3.3V, any accidental short risks blowing up the regulator - it is normal to connect switches between GPIO and Gnd
See https://elinux.org/RPi_GPIO_Interface_Circuits.
It is also good practice to use a series resistor ~1kΩ to protect the GPIO if it is configured as output.
See I am getting ghosting/bouncing on my digital input
