I have a raspberry pi 2 Model B and I want to disable the power to ethernet and USB hub port, I try using hub ctrl. c command, and it doesn't work.
Is this happening because of the limitation of the hardware? Will this be working on Raspberry Pi 3 Model B?
Actually, I want to control the USB port. Since there are four USB ports on my raspberry pi 2 model B, I want to know If it is possible to turn off the power of USB ports with software, not with hardware.
Mohi Rostami
  • 4,434
  • 39
Wei Lin
  • 41
Installation
You can block the power of all USB ports by the following procedure.
sudo apt-get install libusb-dev git
Get the required source:
git clone https://github.com/codazoda/hub-ctrl.c
Go to the new directory by cd hub-ctrl.c and install it:
gcc -o hub-ctrl hub-ctrl.c -lusb
Usage
Turn off Ethernet Port:
sudo ./hub-ctrl -h 0 -P 1 -p 0
Turn on Ethernet Port:
sudo ./hub-ctrl -h 0 -P 1 -p 1
Turn off all USB Ports:
sudo ./hub-ctrl -h 0 -P 2 -p 0
Turn on all USB Ports:
sudo ./hub-ctrl -h 0 -P 2 -p 1
Yes, you can use it on Raspberry Pi 3B. The Raspberry Pi 2 has this feature to cut/block the power of USB ports. If this procedure doesn't work, you accomplish it by uhubctl. It supports Raspberry Pi models B+, 2B, 3B, 3B+, and 4B.
Another approach is binding/unbinding the individual post but not work on all types of connected devices.
References:
Mohi Rostami
  • 4,434
  • 39
