25
Currently, there in no version of Dropbox for ARM Linux variants, there is an article here
https://www.dropbox.com/votebox/358/linux-arm-support
I've use Cubby, Google Drive, DropBox, Wuala, SpiderOak and probably a few others, but haven't found anything which supports ARM Linux.
I'm thinking of using Mercurial and syncing using a repository.
It would be extremely useful to be able to have files in a tools cubby - then I could download on a Mac or PC and drop in that folder and then have it available on the device.
syb0rg
  • 8,178
  • 38
Cade Roux
  • 2,117
11 Answers11
11
A quick solution would be to use rsync, which makes a local directory look identical to a remote one. Unlike DropBox, you would just have to perform the sync operation manually when you wanted things up to date.
Unlike a version control system like Mercurial, rsync won't keep history or backups, so it is very easy to accidentally delete files (or very hard, depending on your point of view - a sync might just download your deleted files again.)
Malvineous
  • 2,109
  • 25
Is http://owncloud.org of any use? is open-source and linux based.
Jon Egerton
  • 3,083
For Google Drive, have a look at grive. It's still beta as of July 2012. I didn't try to build it, but it's open source and its dependencies look like they could be built on ARM.
Alex Chamberlain
  • 15,638
elmicha
  • 218
Have a look at git-annex. Joey is working on it to get a better Open Source replacement for Dropbox.
Jakob
  • 2,768
  • 22
Since Raspbian has fuse I would think fuse-dropbox would work.
techraf
  • 4,353
  • 43
gregp203
  • 61
I use Unison for all such synchronization, when I feel a DVCS would be overkill. Essentially it works like an intelligent two-way rsync of two folders, often through ssh. A simple example:
pi@raspberry ~ $ sudo apt-get install unison2.27.57
pi@raspberry ~ $ unison /home/pi/stuff ssh://server.example.com/stuff
For the first sync it will explain what is going on, then each time you run the same command it will show you changes and sometimes conflicts. If you want it in cron, set up passwordless ssh authentication and run with the options "-batch -silent".
Useful options:
-times  Always synchronizes modification time (should have been default!)
-ignore For ignoring paths/files
-path   For only synchronizing part of the directory (for speed)
-batch  No user interaction
-terse  Only useful output
-silent Only output errors
These options can also go in a configuration file. If you create "/home/pi/.unison/myserver.prf" you can then run "unison myserver". Check out the online manual and for a good primer "Setting up unison for your mom".
There is lots to learn about unison, and the configuration file format is a little weird. But I highly recommend it, as it really replaces dropbox and similiar services. I synchronize terabytes between lots of machines and it works great. The 2.27.57 version is available on most platforms (linux, windows, osx).
Pontus
  • 171
Try Seafile running on RPi. Owncloud is more popular, but less secure. Plus parts of Seafile are written in Python, official language for RPi.
You can download RPi version from Seafile official website:
http://www.seafile.com/en/download/
Then you can use very detailed tutorial on how to setup Seafile on RPi:
http://draptik.github.io/blog/2014/04/21/installing-seafile-on-raspberry-pi/
den.run.ai
  • 131
Have you tried SparkleShare?
SparkleShare is an Open Source collaboration and sharing tool that is designed to keep things simple and to stay out of your way. It allows you to instantly sync with Git repositories and is available for Linux distributions, Mac and Windows.
The only backend requirements for SparkleShare is Git, and that is available on the Raspberry Pi.
Robert Munteanu
  • 274
Crashplan on Squeezeplug. You can manage by redirecting / tunneling port.
Lukas Knuth
  • 949
Chaz
Or you can use sshfs to mount a folder like a remote drive. I wrote a small tutorial here.
I hope it helps
Lukas Knuth
  • 949
Advanced
  • 111
The main use of my Raspberry Pi are BT and BT Sync.
Documentation of BT Sync can be found here. BT Sync for ARM Linux can be download from here.
Here is a tutorial.
ohho
  • 299
