I want to use the ds2482 kernel module/driver but I'm struggling to find an example to start with. I've googled many searches but I swamped with git trees and source trees.
I've loaded it OK and it shows with lsmod.
What I'm looking for is some c code and a header file. The header file in the kernel source is a blank file so I'm really at a loss at the moment.
You may ask why not use the ow system, the reason is that I want to control the timing of the readings.
So I any one could point me in the right direction I'd be really happy.
Impulss
  • 906
AndyNC
If you want to use the module you can just load it up with modprobe
$ sudo modprobe ds2482
CoolUser
  • 121
You can probably use these functions which are shown in this document
If you want to see kernel code in your system you have to install/download kernel source package.
You should check this Kernel Space - User Space Interfaces document for kernel space - user space interactions.
cagdas
  • 41
