I have an issue that means I have to use a powered USB hub for the HDD that is attached to my RPI4 (long story). The hub just broke.
My budget doesn't allow for a decent powered USB3 hub BUT does allow for a decent USB3 Y Power Cable.
Rookie question, but would this work? I just want the HDD to have its own power supply.
Further question: If it would work, can I just plug both Y ends of the power cable into the Pi to get more power for the HDD?
Cheers!
lukenm
  • 193
This answer is incorrect.
Depending on model & OS USB can supply 1.2A. Typical Power Requirements
I doubt it would work, according to this page: USB - port power limits the Raspberry Pi USB ports are designed to handle 100mA each so the advice is to always use an external hub with its own power supply for a USB hard drive (and other "high-power" devices).
ON5MF Jurgen
  • 313
I think that at the very least you should consider using a separate power adapter on the usb-power connector end of the cable. As otherwise, plugging both usb ends to the Pi4/Pi400 ports won't give any more power to the HDD.
P.s. For awareness I posted a similar question specifically regarding pros/cons of powering the HDD this way that might interest you
Y-Cable and power adapter to power external HDD
luckyluca
