I try to understand how to generate IR carrier frequency with the raspberry and how PWM and NEC work visually. I learn PWM but I cannot find any explication of duty cycle. Ok it's a percentage of HIGH state on 1 cycle or 1 period or 1Hz ... But what is the require duty-cycle for IR LED and what is related to ? I have create this picture :
I have also read this dicussion : Notes-on:-Pulse-Width-Modulation-(PWM) , control-hardware-pwm-frequency and driving-pwm-output-frequency
I have written a script capable to find GPIO PWMC and PWMR configuration values, then the output of my script is:
Enter the frequency in Hz : 38000
Enter the tolerance in % : .1
Tolerance: 0.1% (38 Hz)
PWMC:5, PWMR:101, PWM_RESOLUTION:0.3 us/unit, PWM_PERIOD:26.3 us, PWM_FREQ:38019.8 Hz       DIFF:+19.8 Hz
PWMC:101, PWMR:5, PWM_RESOLUTION:5.3 us/unit, PWM_PERIOD:26.3 us, PWM_FREQ:38019.8 Hz       DIFF:+19.8 Hz
PWMC:505, PWMR:1, PWM_RESOLUTION:26.3 us/unit, PWM_PERIOD:26.3 us, PWM_FREQ:38019.8 Hz      DIFF:+19.8 Hz
PWMC must be only an predefined even number ? ( In this case my script is wrong) The nearest divider for a 38KHz carrier seems to be BCM2835_PWM_CLOCK_DIVIDER_512 = 512, /*!< 512 = 37.5kHz */
Ephemeral
  • 2,167
A 38 KHz PWM carrier has 38000 cycles per second. Each cycle takes 1 million / 38 thousand microseconds, so approximately 26 microseconds per cycle.
The dutycycle is the percentage time the PWM signal is high per cycle.
Infrared devices use mark space PWM rather than balanced PWM. All you need to know is that mark space means the signal goes from high to low just once per cycle.
For infrared signals I tend to use 50% dutycycle, so on for 13 µs then off for 13 µs. Commercial devices (i.e. remote controls) tend to use something like 30% dutycycle, so on for 8 µs, off for 18 µs. They only do that to save power so I'd stick to 50%.
joan
  • 71,852
  • 76
  • 108
