I have a fancy setup to cool my beer at a controlled temperature (you can find details and a photo here if you want). The input of my system is a temperature, the output is a servo position.
Long story short
On startup the servo is stable enough, but every time after 67s of runtime suddenly the servo starts vibrating. I have an oscilloscope and I can see that after 67s, instead of a steady 2.3 ms the length of the pulses oscillate in a small range, like between 2.300 and 2.320 ms, and it's enough of a range to be a problem.
What happens at 67s ?? Is there some kind of overflow ? I'm very puzzled because all in all my code for the pulse is very simple.
I'm having my problem on this code, branch bs18b20 of my repo. The pulse is generated line 293, with custom code.
More context
I had already asked for help right here with my setup. We had determined that using Servo.h along along with the 1Wire protocol make the interruptions used by both libraries get in the way of one another, so the servo receives bad values and vibrates too. In my last comment in this thread I said that the problem was solved, but I discovered later the problem of the servo getting unstable after some time, as exposed above.
To overcome that I changed tactics, switched my bs18b20 for a lm35 which doesn't need 1Wire, and switched back to Servo.h. It worked very well... in my electronics lab. But then (reality sucks) I found out when actually using my device in the kitchen that sometimes the temperatures start getting very wrong, and I suspect that the humidity alters the voltage reading of my lm35. And that's why I'm trying to change back again to my previous solution with a waterproof bs18b20.
While writing this, stackexchange proposed this thread with a very promising solution, I will definitely try that. Nonetheless, for the sake of it, I'm still interested in knowing what causes my problem above, so I'm posting this anyway.
