I have an Arduino with a servo, INA219 (current and voltage sensor) and 2 DS18B20 connected to it.
DS18B20 are connected in full-power mode with 5k resistor connected between DATA line and +5V.
I use DallasTemperature library: https://github.com/milesburton/Arduino-Temperature-Control-Library
I get the temperature readings, but the problem is that my servo is jittering slightly almost every time temperature reading is done. If I disconnect DATA line from pin 2 (where it's normally connected) then servo is not moving anymore and everything is fine.
Any ideas what might be causing it? I would expect servo interfering with OneWire readings, not the other way around :)
Here is the full code: https://pastebin.com/xcES4PVT
Here is the minimal example with which I can reproduce the problem:
    #include <DallasTemperature.h>
#include <Servo.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
Servo myservo;
long previousMillis = 0;
long tempRequestedMillis = 0;
bool tempRequested = false;
void setup(void)
  // start serial port
  Serial.begin(115200);
  Serial.println("Dallas Temperature IC Control Library Demo");
  myservo.attach(9);
  // Start up the library
  sensors.begin();
  sensors.setWaitForConversion(false);
void loop(void)
  unsigned long currentMillis = millis();
  if (!tempRequested && currentMillis - previousMillis > 2000) {
    previousMillis = currentMillis;
    sensors.requestTemperatures(); // Send the command to get temperatures
    tempRequestedMillis = currentMillis;
    tempRequested = true;
  } else if (tempRequested && currentMillis - tempRequestedMillis > 2000) {
    Serial.println(sensors.getTempCByIndex(0));
RubberDuck
  • 332
Leonti
  • 133
Arduino's Servo library on AVR uses interrupts; if interrupts are disabled for any amount of time, the servos will twitch.
1-Wire protocol (used by DS18B20) needs to disable interrupts for the protocol to work. Therefore, servos glitch.
There is a great explanation of the problem here: https://learn.adafruit.com/neopixels-and-servos/overview , just mentally replace "Neopixel library" with "OneWire library". Their TiCo_Servo library sounds just like what you want.
theamk
  • 176
Reading a DS18B20 the naive way takes up to 1500ms because you have to trigger a temperature conversion, then wait for it to complete.
If you have them full-powered, you better trigger the conversion, continue with your program and read the result 2 seconds later, when it's done. You can also trigger the conversion on all connected DS18B20 simultaneously by using the Skip ROM command before sending the Convert T command.
Please see the documentation of Maxim/Dallas' library how to do that.
