23
I wanted to make a fairly simple circuit which would flash a series of LEDs in sequence, using my Arduino Uno (more specifically, a SainSmart clone). I wrote my sketch and it compiled fine. After that, I connected 8 LEDS+resistors to pins 0 through 7, and then connected the Uno to my computer via USB.
I've uploaded sketches successfully in the past, so I'm sure my settings and drivers etc. are correct. However, when I tried to upload my sketch this time, it didn't work.
I tried removing everything I'd connected to the Arduino's pins, and suddenly the upload worked again.
Why does this happen? Does it mean I have to disconnect everything from the board every time I upload a sketch?
Anonymous Penguin
  • 6,365
  • 34
  • 62
Peter Bloomfield
  • 10,982
  • 48
The problem is specifically pins 0 and 1. Although they can be used as regular digital IO pins, they also serve as the RX and TX pins for the Uno's serial port. The USB connection (for uploading sketches etc.) is routed to the same pins internally. Unfortunately that means anything connected on pins 0 and 1 can interfere with the serial connection, preventing communication via USB.
In short, it's not necessary to disconnect everything when uploading a sketch. It should only be necessary to disconnect anything from pins 0 and 1. Rather than going through that hassle every time a sketch is uploaded though, it may be best just to avoid using those pins unless necessary (e.g. you run out of other pins, or your project needs a serial connection to another device).
Peter Bloomfield
  • 10,982
  • 48
" Peter R. Bloomfield " I used to upload sketch in my arduino uno by connecting Rx and Tx pin but my sketch get uploaded. Actually problem is arduino uno driver may be deleted in your case
Uttam
  • 55
