I am building a project using bluetooth control as well as an ir sensor. The logic behind my program is when I press a key I want my robot to execute a series of program and while the program is executing if an obstacle is detected I need the motors to stop and then continue from the same point after the obstacle is removed. I am uploading my code for ref.
#include <Servo.h>
#include <AFMotor.h>
#include <Servo.h>
int obstaclePin = 12;
int obstacle = LOW;
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
Servo myservo1;
Servo myservo2;
int pos = 0;
char bt='S';
void setup()
Serial.begin(9600);
pinMode(obstaclePin,INPUT);
myservo1.attach(10);
myservo2.attach(9);
motor1.setSpeed(100);
motor2.setSpeed(100);
motor3.setSpeed(100);
motor4.setSpeed(100);
Stop();
bt=Serial.read();
if(bt=='F')
forward();
delay(2000);
backward();
delay(2000);
left();
delay(2000);
right();
delay(2000);
Stop();
if(bt=='B')
forward();
delay(8000);
left();
delay(1500);
ServoControl();
delay(500);
backward();
delay(1000);
right();
delay(3000);
forward();
delay(8000);
Stop();
if(bt=='L')
forward();
delay(10000);
left();
delay(1500);
ServoControl();
delay(500);
backward();
delay(1000);
right();
delay(3000);
forward();
delay(10000);
Stop();
if(bt=='R')
forward();
delay(12000);
left();
delay(1500);
ServoControl();
delay(500);
backward();
delay(1000);
right();
delay(3000);
forward();
delay(12000);
Stop();
if(bt=='S')
Stop();
if(bt=='O')
servoOpen();
if(bt=='C')
servoCLose();
void forward()
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
void backward()
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void left()
motor3.run(RELEASE);
motor4.run(RELEASE);
void right()
motor1.run(RELEASE);
motor2.run(RELEASE);
void Stop()
void servoOpen()
for (pos = 0; pos <= 100; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo1.write(pos);
myservo2.write(pos);
void servoCLose()
for (pos = 100; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
void ServoControl()
delay(40); // waits 15ms for the servo to reach the position
void obstacleD()
obstacle = digitalRead(obstaclePin);
if(obstacle == HIGH)
Stop();
I don't know where to add the obstacle detection so it would work like an interrupt. the main problem I was experiencing was that whenever I tried running the code on my Arduino it would completely change the logic and noting would work even if I put the command in the serial monitor until an obstacle was detected. I'm a newbie at programming and using Arduino.
