Heeya Guys! Today I created a project with the help of instructables site. I followed the on screen steps and everything. Uploaded the sketch and it works like a charm, but there's one problem.
Everything works correctly but not the "Day", i.e as of today its Friday, 9 April 2021, the clock shows the correct time and date but it tells that today is "Tuesday" in place of Friday. I don't know why this is happening. Any help would be appreciated :) Here's the code that I'm using:
/*Arduino Clock by AnthoTRONICS
* Last edit: March 22,2019
// Libraries you'll need (Same as the ones in the guide:
// TAKE NOTE OF THE VERSIONS!!!
// MD Parola 3.0.1: https://github.com/MajicDesigns/MD_Parola // click the link to download the library
// MD_MAX72XX 3.0.2: https://github.com/MajicDesigns/MD_MAX72XX //click the link to download the library
// DS3231 1.0.2: https://github.com/NorthernWidget/DS3231 // click the link to download
/CODE:/
// Header file includes
// These are for the matrix
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include "Font_Data.h"
//These are for the clock
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte dd,mm,yyy;
uint16_t h, m, s;
#define MAX_DEVICES 4 // Set the number of devices
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// Hardware SPI connection
MD_Parola P = MD_Parola(HARDWARE_TYPE,CS_PIN, MAX_DEVICES);
#define SPEED_TIME 75 // speed of the transition
#define PAUSE_TIME 0
#define MAX_MESG 20
// Global variables
char szTime[9]; // mm:ss\0
char szMesg[MAX_MESG+1] = "";
uint8_t degC[] = { 6, 3, 3, 56, 68, 68, 68 }; // Deg C
uint8_t degF[] = { 6, 3, 3, 124, 20, 20, 4 }; // Deg F
char mon2str(uint8_t mon, char psz, uint8_t len)
// Get a label from PROGMEM into a char array
static const __FlashStringHelper* str[] =
F("Jan"), F("Feb"), F("Mar"), F("Apr"),
F("May"), F("Jun"), F("Jul"), F("Aug"),
F("Sep"), F("Oct"), F("Nov"), F("Dec")
strncpy_P(psz, (const char PROGMEM *)str[mon-1], len);
psz[len] = '\0';
return(psz);
char dow2str(uint8_t code, char psz, uint8_t len)
F("Sunday"), F("Monday"), F("Tuesday"),
F("Wednesday"), F("Thursday"), F("Friday"),
F("Saturday"), F("Sunday")
strncpy_P(psz, (const char PROGMEM *)str[code-1], len);
psz[len] = '\0';
return(psz);
// Time Setup: Code for reading clock time
void getTime(char psz, bool f = true)
s = Clock.getSecond();
m = Clock.getMinute();
h =Clock.getHour(h12,PM); //24hr Format
sprintf(psz, "%02d%c%02d", h, (f ? ':' : ' '), m);
//12hr Format
//uncomment if you want the clock to be in 12hr Format
/if (Clock.getHour(h12,PM)>=13 || Clock.getHour(h12,PM)==0)
h = Clock.getHour(h12,PM) - 12;
else
h = Clock.getHour(h12,PM);
void getDate(char *psz)
// Date Setup: Code for reading clock date
char szBuf[10];
dd=Clock.getDate();
mm=Clock.getMonth(Century); //12
yyy=Clock.getYear();
sprintf(psz, "%d %s %04d",dd , mon2str(mm, szBuf, sizeof(szBuf)-1),(yyy + 2000));
//strcpy(szMesg, "29 Feb 2016");
void setup(void)
P.begin(2);
P.setInvert(false); //we don't want to invert anything so it is set to false
Wire.begin();
P.setZone(0, MAX_DEVICES-4, MAX_DEVICES-1);
P.setZone(1, MAX_DEVICES-4, MAX_DEVICES-1);
P.displayZoneText(1, szTime, PA_CENTER, SPEED_TIME, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
P.displayZoneText(0, szMesg, PA_CENTER, SPEED_TIME, 0,PA_PRINT , PA_NO_EFFECT);
P.addChar('$', degC);
P.addChar('&', degF);
void loop(void)
static uint32_t lastTime = 0; // millis() memory
static uint8_t display = 0; // current display mode
static bool flasher = false; // seconds passing flasher
P.displayAnimate();
if (P.getZoneStatus(0))
switch (display)
case 0: // Temperature deg C
P.setPause(0,1000);
//P.setTextEffect(0, PA_SCROLL_LEFT, PA_SCROLL_UP);
P.setTextEffect(0, PA_MESH, PA_BLINDS);
display++;
dtostrf(Clock.getTemperature(), 3, 1, szMesg);
strcat(szMesg, "$");
//strcat(szMesg, "26.5$");
break;
case 1: // Temperature deg F
//P.setTextEffect(0, PA_SCROLL_UP, PA_SCROLL_LEFT);
P.setTextEffect(0, PA_OPENING, PA_GROW_DOWN);
display++;
dtostrf((1.8 *Clock.getTemperature() )+32, 3, 1, szMesg);
strcat(szMesg, "&");
// strcpy(szMesg, "71.6&");
break;
case 2: // Clock
P.setFont(0, numeric7Seg);
P.setTextEffect(0, PA_PRINT, PA_NO_EFFECT);
//Sleep Mode
//Uncomment to enable Sleep Mode and adjust the hours to your needs
/*if (h==12 || h<8)//Time intervals (in this case, from 12AM to 8AM)
P.setIntensity(0); //Set display brightness to lowest setting
else
P.setIntensity(6); //Set display brightness to 6 (15 is the brighest)
P.setPause(0,0);
if (millis() - lastTime >= 1000)
lastTime = millis();
getTime(szMesg, flasher);
flasher = !flasher;
if(s==00&& s<=30){
display++;
P.setTextEffect(0, PA_PRINT, PA_SCROLL_UP);
// strcpy(szMesg, "36 % RH");
break;
case 3: // day of week
P.setFont(0,nullptr);
P.setTextEffect(0, PA_SCROLL_LEFT, PA_SCROLL_LEFT);
display++;
dow2str(Clock.getDoW()+1, szMesg, MAX_MESG); // Added +1 to get correct DoW
//dow2str(5, szMesg, MAX_MESG);
break;
default: // Calendar
display = 0;
getDate(szMesg);
break;
P.displayReset(0);
