SOLVED: after may hours of testing i have solved the problem. it turned out to not be a software issue. the power supply i was using did not have a flyback diode and thus caused large voltage spikes that would crash the esp. the solution was to add a diode on the inductive load to remove those voltage spikes.
I have an esp-01 running some code that checks for a rf remote signal using the rc-switch library, it is also running some blynk and ota code.
when i press one of the buttons on my rf remote the buzzer pin keeps being triggered but will not shut off, eventually the esp will crash..
the device is in a permanent location thus the reason for the ota updates and i cant easily hookup a serial monitor to see what the esp crash code is.
the troublesome code is,
    void newloop() {
      if (mySwitch.available()) {
        // int recieved = mySwitch.getReceivedValue();
        if (mySwitch.getReceivedValue() == 5099665) {
          digitalWrite(buzzer, LOW);
          delay(200);
          digitalWrite(buzzer, HIGH);
          mySwitch.resetAvailable();
        else if (mySwitch.getReceivedValue() == 5099666) {
          delay(2000);
      // Blynk.run();
the full code, with redacted passwords/keys is,
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <ESP8266WebServer.h>
#define BLYNK_PRINT Serial #include <RCSwitch.h> #include <ESP8266WiFi.h> #include <BlynkSimpleEsp8266.h> #define buzzer 2 char auth[] = "<blynk auth>"; RCSwitch mySwitch = RCSwitch();
const char* ssid = "HansenHome"; const char* password = "<wifi password>"; ESP8266WebServer server;
bool ready = false; bool ota_flag = true; uint16_t time_elapsed = 0;
Serial.begin(115200); Serial.println("Booting"); WiFi.mode(WIFI_STA); WiFi.begin(ssid, password);
pinMode(buzzer, OUTPUT); digitalWrite(buzzer, HIGH); Blynk.begin(auth, ssid, password); mySwitch.enableReceive(0);
while (WiFi.waitForConnectResult() != WL_CONNECTED) { Serial.println("Connection Failed! Rebooting..."); delay(5000); ESP.restart(); }
// Hostname defaults to esp8266-[ChipID] ArduinoOTA.setHostname("lock");
// No authentication by default ArduinoOTA.setPassword("<uploading password>");
ArduinoOTA.onStart( { String type; if (ArduinoOTA.getCommand() == U_FLASH) { type = "sketch"; } else { // U_SPIFFS type = "filesystem"; }
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println(&quot;Start updating &quot; + type);
}); ArduinoOTA.onEnd( { Serial.println("\nEnd"); }); ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) { Serial.printf("Progress: %u%%\r", (progress / (total / 100))); }); ArduinoOTA.onError([](ota_error_t error) { Serial.printf("Error[%u]: ", error); if (error == OTA_AUTH_ERROR) { Serial.println("Auth Failed"); } else if (error == OTA_BEGIN_ERROR) { Serial.println("Begin Failed"); } else if (error == OTA_CONNECT_ERROR) { Serial.println("Connect Failed"); } else if (error == OTA_RECEIVE_ERROR) { Serial.println("Receive Failed"); } else if (error == OTA_END_ERROR) { Serial.println("End Failed"); } }); ArduinoOTA.begin(); Serial.println("Ready"); Serial.print("IP address: "); Serial.println(WiFi.localIP());
server.on("/restart",{ server.send(200,"text/plain", "Restarting..."); delay(1000); ESP.restart(); });
server.on("/setflag",{ server.send(200,"text/plain", "Setting flag..."); ota_flag = true; time_elapsed = 0; });
server.begin(); }
void loop() { if(ota_flag) { uint16_t time_start = millis(); while(time_elapsed < 10000) { ArduinoOTA.handle(); time_elapsed = millis()-time_start; delay(10); } ota_flag = false; } if(ready == false) { ready = true; digitalWrite(buzzer, LOW); delay(20); digitalWrite(buzzer, HIGH); delay(20); digitalWrite(buzzer, LOW); delay(20); digitalWrite(buzzer, HIGH); delay(20); digitalWrite(buzzer, LOW); delay(20); digitalWrite(buzzer, HIGH); delay(20); digitalWrite(buzzer, LOW); delay(20); digitalWrite(buzzer, HIGH); ready = true; } server.handleClient(); newloop(); }
BLYNK_WRITE(V1) { digitalWrite(buzzer, LOW); delay(200); digitalWrite(buzzer, HIGH); }
void newloop() { if (mySwitch.available()) { // int recieved = mySwitch.getReceivedValue(); if (mySwitch.getReceivedValue() == 5099665) { digitalWrite(buzzer, LOW); delay(200); digitalWrite(buzzer, HIGH); mySwitch.resetAvailable(); } else if (mySwitch.getReceivedValue() == 5099666) { digitalWrite(buzzer, LOW); delay(2000); digitalWrite(buzzer, HIGH); mySwitch.resetAvailable(); } } // Blynk.run(); }
EDIT:
so after so further testing it appears to be a power supply issue, the power supply i was using was hooked up to a large inductive load. once that load is turned off there is a huge power spike and for some reason causing the esp to crash.
the board the esp is on has 2 voltage regulators and a few input caps
i added a large cap to the main supply and a 100uf to the 3.3v rail directly on the esp. it is still crashing..
alex
