When using the deep sleep functionality on several ESP-01 boards, the boards require two resets in order to wake up properly (regardless of whether the resets are done by manually bridging the rst pin or by soldering a wire to do it from an interrupt). The boards do wake up and print some text automatically, but they do not run their firmware/code.
#include <ESP8266WiFi.h>
    Serial.begin(74880);
    Serial.print("\n--------------STARTING----------------\n");
//pinMode(LED_BUILTIN, OUTPUT);     // Initialize the LED_BUILTIN pin as an output
//digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off (gpio @ high= off)
delay(500);
ESP.deepSleep(2000000, WAKE_RF_DEFAULT );
void loop() { }
I have not been able to just wake the board and run the code like most examples on the web intend to work, so I suppose the problem is not with this code.
On a successful wake up, the serial output looks like this:
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3456, room 16
tail 0
chksum 0x84
csum 0x84
va5432625
~ld
After the first reset, the board does indeed wake up, but it does not run it's code. It only prints this
And then hangs there. After another reset, it successfully runs it's code.
This issue persists across all the esp 01 boards i own, and i have tried pulling UP and DOWN almost every combination of pins recommended. The line that is printed in the fauly cases does indeed say it is booting in the right mode, but still the code does not run, nor mine nor the one that runs before mine
sassoPera
  • 303
What sasso is describing is classic Deep Sleep Zombie mode. There's someone else here with ESP-01 boards with the same issue. I'd bet you got your boards in blister packs from Inland. I didn't see any ESP-01 boards from Inland at my local computer store, only ESP-01S, and that one works with Deep Sleep just fine. I only bought the one for a test. I believe it's the Flash chip, but we haven't proven that yet. I have plenty of Winbond flash in case I find a board that goes zombie, and can prove or disprove my theory. I have 8 different types of boards and modules, and all come out of Deep Sleep correctly.
edit: If the pic at Ali is correct, the Puya Flash shouldn't be causing an issue, presuming it's real and not a clone. Half the time the pics are only 'representative examples' of what they ship. The ESP8266 Arduino core has supported Puya for a while now. Also, on sober reflection the Inland package I bought said ESP-01S, and it's actually an ESP-01 (false advertising). I looked closer and didn't see the pull-up resistors. :-(
If you're powering it from that USB programmer board, it should work. If you have a separate 3.3V supply, I'd be suspicious of the supply. The current spikes as the ESP is booting will cause many switching supplies to drop below 2V briefly, and the ESP goes insane. Without having a zombie in front of me, I'm at a loss to go a lot further as my 'scope leads aren't that long.
Krazy OldGuy
  • 156
