I'm using the Max7219 (8 digits, 7bits) led display to try and make a timer. I have downloaded an example code from the following site to set the led digits:
https://www.brainy-bits.com/arduino-countdown-timer-using-the-max7219-display/
However the original code simply loops as fast as possible and decriment the timer so it is not a true time. I tried to add a 10 ms delay to make it decriment 10ms on the right most digit so the 3rd digit to the right would be seconds, however I found this to be inaccurate and taking slightly longer than 1 second .
My question is is it possible to make a timer with 1ms accuracy using led display and if so how do I do it?
/* CountDown Timer version 2 using Max7219
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
You can: copy it, use it, modify it, share it or just plain ignore it!
Thx!
#define Max7219DIN 7 // Pin 7 connected to DIN (DataIN)
#define Max7219CLK 6 // Pin 6 connected to CLK
#define Max7219CS 5 // Pin 5 connected to CS
#define Buzzer 8 // Pin 8 connected to Buzzer +positive pin
int BuzzTrigger=0; // Variable to store buzzer trigger value
#include "LedControl.h" // LedControl Library created by Eberhard Fahle at http://playground.arduino.cc/Main/LedControl
LedControl lc=LedControl(Max7219DIN,Max7219CLK,Max7219CS,1); // Last number represent the number of Max7219 Modules connected
long int countnumber=24001000 ; // Countdown timer start value HH:MM:SSSS
// Variables to store individual numbers
int firstnum=0;
int secondnum=0;
int thirdnum=0;
int fournum=0;
int fivenum=0;
int sixnum=0;
int sevennum=0;
int eightnum=0;
lc.shutdown(0,false); // Wake up the display
lc.setIntensity(0,7); // Set Brightness 0-15
lc.clearDisplay(0); // Clear display
pinMode(Buzzer, OUTPUT);
digitalWrite(Buzzer, LOW); //Buzzer Off at startup
for (countnumber; countnumber != -1; countnumber--) {
String mystring = String(countnumber); // Transform Counter Int to String for manipulation
// Convert number to a time value
for (int z = 0; z < 6; z++) {
if (mystring.substring(z) == "999999") {
countnumber = (countnumber - 400000);
if (mystring.substring(z) == "9999") {
countnumber = (countnumber - 4000);
// Display number on Display depending on number of digits remaining
if (countnumber > 9999999) {
firstnum = ((countnumber / 10000000) % 10);
secondnum = countnumber / 1000000 % 10;
thirdnum = countnumber / 100000 % 10;
fournum = countnumber / 10000 % 10;
fivenum = countnumber / 1000 % 10;
sixnum = countnumber / 100 % 10;
sevennum = countnumber / 10 % 10;
eightnum = countnumber % 10;
lc.setDigit(0, 7, firstnum, false);
lc.setDigit(0, 6, secondnum, false);
lc.setDigit(0, 5, thirdnum, false);
lc.setDigit(0, 4, fournum, false);
lc.setDigit(0, 3, fivenum, false);
lc.setDigit(0, 2, sixnum, false);
lc.setDigit(0, 1, sevennum, false);
lc.setDigit(0, 0, eightnum, false);
delay(10); //<<<<<<<<<<< I ADDED THIS
} else {
if (countnumber > 999999) {
// firstnum = ((countnumber/10000000)%10);
lc.setChar(0, 7, '-', false);
} else {
if (countnumber > 99999) {
// secondnum = countnumber/1000000%10;
lc.setChar(0, 6, '-', false);
} else {
if (countnumber > 9999) {
// thirdnum = countnumber/100000%10;
lc.setChar(0, 5, '-', false);
delay(10);//<<<<<<<<<<< I ADDED THIS
} else {
if (countnumber > 999) {
// fournum = countnumber/10000%10;
lc.setChar(0, 4, '-', false);
} else {
// fivenum = countnumber/1000%10;
a
lc.setChar(0, 3, '-', false);
new implementation using millis
unsigned long countnumber;
int firstnum=0;
int secondnum=0;
int thirdnum=0;
int fournum=0;
int fivenum=0;
int sixnum=0;
int sevennum=0;
int eightnum=0;
Serial.begin(9600);
countnumber = millis();
firstnum = countnumber / 10000000 % 10;
