So am I using an Arduino with a shield to gain some voltage values for an ECG. I am then plotting that data in Python. However whenever I "observe" the serial port, be that through the Arduino serial monitor or in attempting to plot the values of time (using millis()) against ECG (voltage) the values reset, so millis() resets the zero, which is fine, except that some of the older values still show up. Now this is especially a problem in Python because it means the plot is malfunctioning at the start of the script, because it is plotting some of the older values and then after a couple of seconds it resets and the plot looks normal again.
To demonstrate this I have recorded it on video and put it on YouTube, here it is:
https://www.youtube.com/watch?v=dNpUakcRPec
Now initially I thought the problem was with Python or the Pyserial module so I labelled the video as such, but since it occurs in the serial monitor I realised the solution would be in the Arduino sketch. I have tried flushing, didn't work, I have tried even to not start the data till I send a start byte, but this didn't work on Python.
Ideally I could start the Python plotting script and it would skip, or ignore those initial values from the serial port before beginning again.
Here is the Arduino sketch I am using:
#include <eHealth.h>
unsigned long time;
// The setup routine runs once when you press reset:
  Serial.begin(9600);
// The loop routine runs over and over again forever:
  float ECG = eHealth.getECG();
  time = millis();
  Serial.print(time);
  Serial.print(" ");
  Serial.print(ECG, 3);
  Serial.println("");
  delay(50);    // wait for 50 millisecond
hawkar
  • 553
The Arduino is designed to reset when a Serial monitor or script connects to it. The best way to mitigate this would be to send the Arduino some kind of "start sending" signal when you connect to the serial port. It would then send the data when your script was ready.
TheDoctor
  • 3,509
  • 22
  • 39
Take a look at if(Serial)
That makes the Sketch wait for the serial port before continuing.
//Initialize serial and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
; // wait for serial port to connect.
I have a sneaking suspicion that may only work on the Leonardo.
If so you could try an alternative:
  1. Have Python send something to Arduino after it connects.
  2. Wait until this is received in setup(): if (Serial.available() > 0) {...}
  3. Execute the loop() normally
e.g.
// send data only when you receive data:
            // read the incoming byte:
            incomingByte = Serial.read();
            // say what you got:
            Serial.print("I received: ");
            Serial.println(incomingByte, DEC);
akellyirl
  • 2,156
I the answer from @TheDoctor. An alternative is for the client listening on serial port to wait for a "successful reset" signal from the Arduino.
    Serial.begin(9600);
    while (!Serial) {
    Serial.println('reset successful')
There are pros and cons to each solution. In the @TheDoctor solution, it seems like there is an edge cases where the Arduino is already sending when the client connects and you'll get some junk before the reset occurs.
bfris
  • 101
