How should I inherit from Stream, for creating a new class MySerial able to be initialized from a Stream0 instance?.
The error so far is: "cannot declare variable 'mySerial' to be of abstract type 'MySerial'".
If I make a class MySerial not inheriting, but adding a property Stream, everything works fine, except the new call mechanism for the resend() function, created to accept Stream instances.
EDIT: This is the edited code. Current error is: "expected unqualified-id before '=' token".
MySerial.h
class MySerial:public Stream{
    private:
        int param;
    public:
        MySerial(){}; // OK
        MySerial(Stream &Serial0){MySerial=&Serial0} // Here is the question
        // Stream Implementation
        int available(){return available();}
        int read(){return read();}
        int peek(){return peek();}
        size_t write(uint8_t c){return write(c);}
        using Print::write;
MySerial.ino
#include <MySerial.h>
#include <SoftwareSerial.h>
SoftwareSerial swSerial(6,7);
MySerial mySerial(swSerial);
void setup(){}
void loop(){
    if (mySerial.available()){
        c=mySerial.read();
        resend(mySerial,c);
// This function should accept any Stream: SoftwareSerial, MySerial, Serial...
void resend(Stream &Stream0, char c){
    Stream0.write(c);
VE7JRO
  • 2,515
  • 29
Brethlosze
  • 337
The Stream class has pure virtual methods which must be implemented in derived not abstract class.
The pure virtual method from base class Print is:
virtual size_t write(uint8_t) = 0;
The pure virtual methods from Stream are:
virtual int available() = 0;
virtual int read() = 0;
virtual int peek() = 0;
additionally add in your class the line
using Print::write;
to pull in overloaded methods write(str) and write(buf, size) fromPrint
Here I have an example of a simple class derived from Stream.
EDIT: Most of your question seemed to focus on wrapping some Stream implementation. Now I see that you maybe want to enhance the SoftwareSerial class and add a new method in the inherited class. It is simple:
MySerial.h
#ifndef _MYSERIAL_H_
#define _MYSERIAL_H_
class MySerial: public SoftwareSerial {
private:
  int param;
public:
  MySerial(uint8_t receivePin, uint8_t transmitPin) :
      SoftwareSerial(receivePin, transmitPin, false) {
    param = 0;
  void resend(char c) {
    write(c);
#endif
MySerial.ino
#include "MySerial.h"
MySerial mySerial(6, 7);
  mySerial.begin(9600);
  if (mySerial.available()) {
    int c = mySerial.read();
    mySerial.resend(c);
Juraj
  • 18,264
  • 49
